10-06-2010
Installing a "fuel whistle" will help prevent overfilling.
A lot depends on where the fuel tank vent is, where the deck fill is located and where the tank is in relation to the other two... If the vent is higher than the deck fill, then you're task is relatively simple...fill the tank slowly, stop when it is showing fuel in the fuel filler hose.  If the vent is lower than the deck fill, it is a bit more complicated, since you don't want to fill the tank to the point the fuel spills out the vent line.
It would help if you knew roughly how big the tank was and roughly how much fuel was in the tank at the moment. You may want to make up a calibrated "dip stick" for the tank, if the tank has an internal inspection hatch or the fuel filler runs straight down to the tank.
