10-06-2010
Advocate777
coastal seas vs. blue water: difference?
What is the wind and sea conditions difference between 'coastal' cruising and 'blue water' cruising. Specifically. Is it the miles that you actually sail on the ocean away from land? For example, Miami to Bimini is 'only' 42 miles but it is crossing the Gulf Stream, you are out of sight of land.....isn't that 'blue water' cruising? Is it only blue water cruising if a North wind stirs up the Stream? And isn't there a body of water off the east coast of Puerto Rico that is also considered by some to be 'blue water' and not coastal cruising? Or, is it only consider blue water cruising if you are crossing an ocean, or at least at sea for 3 or 4 days? Like from the Chesapeake to Bermuda, clearly blue water. But is it the 'distance' away from land or the 'wind and sea' conditions' that determine if it is 'blue water'. I kinda thought anytime you were sailing in the ocean, out of sight of land, even just parallel to a coast that is 15 miles away it is still 'blue water'. This is a key thing for me to understand when I buy my next boat.
What are the qualities of the sea that makes one consider that it is 'blue water' or 'coastal' and what is the difference in a 32 foot sailboat that someone says 'it is not a blue water' vessel or 'it IS a blue water vessel'.
Thanks, I need to understand this.
Chesapeake Bay area
