10-10-2010
Originally Posted by swampcreek
Weight difference between 25 and 27' is probably nominal and should be no problem. Hull dimension might be a concern as in how and where the bunks hold the boat. If it's close you're probably ok.
Not necessarily true the C25 displacement is around 4500, the C27 6800 from the factory. You can expect another 500-1000lbs of misc on board. If the trailer has two 3500 lb axles you will be overweight by a couple of hundred lbs with the C27. If you have two 4500lb the trailer should be fine.
Jordan
West Wight Potter 14 "Lemon Drop"
SLC UT.
