Old 10-11-2010
tomaz_423's Avatar
tomaz_423 will become famous soon enough
A sailboat turns to port by herself under motor
Hi,
I noticed that a sailboat started to turn to port when I released the wheel and autopilot was off.
The sea was flat and there was practically no wind.
She started to turn slowly, but developed a sharp turn - the rudder all the way, so she circled in small circles.
Is this normal or it indicates a bent rudder?
The boat was a Beneteau Oceanis 473.
Now I can not remember if other boats did the same or I just never let the wheel free under power.
I did not notice this under sail.
preparing to sail away
Old 10-11-2010
smackdaddy's Avatar
Last Man Standing
I don't know anything about the design aspects of the question, but that could potentially be a good safety feature. That is, that if you happen to fall overboard while motoring it would circle.
Of course, you might lose a leg while trying to re-board the motoring boat - but hey, at least the boat is still around. Alternatively, you could just dog-paddle for four days and wait for it to run out of fuel.
Interesting question.
BFS Gear: SNers started it....
Old 10-11-2010
Matvolver is on a distinguished road
That's assuming he doesn't run himself over with his own boat
"Anyone who would give up a little Liberty, for a little Security, deserves neither, and will lose Both" - Benjamin Franklin
Old 10-11-2010
Jeff_H's Avatar
Super Moderator
The answer relates to whether you are motoring or not, and whether the helm actually turned or the boat simply turned. In a general sense, most boats will turn slightly to port when they are motoring due to prop-walk. it can be more pronounced on some boats more than others. (Our 1939 Stadel Cutter was really bad in this regard).
On the other hand, this should not happen when in neutral and the rudder should not turn.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 10-11-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Originally Posted by tomaz_423 View Post
Hi,
what Jeff said.....
Old 10-11-2010
If under power the propwash will often impact on the 'balancing area' of the rudder and tend to push it to one side or the other depending on rotation. The effect is most pronounced on balanced spade rudders, and pretty much non existent on unbalanced rudder designs, which have easy helms under power and sometimes brutes under sail!
You won't notice it under sail, or if it's a situation where the prop is aft of the rudder, such as many cruising cats and boats with outboards..
It's quite normal in our experience.
1984 Fast/Nicholson 345
Sailboat race takes name from sponsor - Port Huron Times Herald NewsReader News Feeds 0 08-04-2007 07:15 AM
Port Huron-to-Mackinac Island Sailboat Race underway - WZZM NewsReader News Feeds 0 07-25-2007 09:15 AM
Sailboat sinks after inspection - State Port Pilot NewsReader News Feeds 0 11-15-2006 04:15 PM
Port Huron-to-Mackinac Island Sailboat Race C-JEM dedicates win to ... - Port Huron Times Herald NewsReader News Feeds 0 08-17-2006 09:15 AM
Port Huron-to-Mackinac Island Sailboat Race C-JEM dedicates win to ... - Port Huron Times Herald NewsReader News Feeds 0 07-19-2006 08:15 AM
