How best to cope with shifty gusts while running? - Page 2 - SailNet Community
post #11 of 23 Old 10-19-2010
Originally Posted by zedboy View Post
Yeah, but headed upwind if you get a little overpowered by the puff, head up and starve the sails a little too much, you'll de-power and the boat will chill out (unless there's way too much wind).
Heading further down while running without touching the sheet puts you at risk for very un-chilled-out stuff...
True that... But most boats have a limit to how far out the mainsail can go...
sailingdog is offline
post #12 of 23 Old 10-19-2010
RichH's Avatar
RDoc----
Your boat has a water ballasted drop keel, right?
Best for such a lightweight boat is to pull the keel up a bit, so that when going downwind and hit with a gust the boat will 'skid' a bit instead of having the keel 'bite' which causes increased heeling moment if the keel turns 'any direction' not parallel to the boats movement direction.
For downwind sailing in gusts, go 'down' in the gusts and 'up' in the slows .... and the most important is to KEEP THE BOAT DIRECTLY **UNDER** THE MAST; dont head up or you ARE going to heel over quite a bit. Since this is a relatively lightweight boat bearing off and going down will result in the boat starting to come on a plane .... "Nantucket Sleighride" so be prepared for some 'bodaceous' boat speed.
Pulling the drop-keel up will aid in the boat's ability to 'automatically' skid-off to a more 'downwind' attitude/direction. If the board/keel is all the way down you have increased risk of 'tripping over the keel' and then going into a 'broach'; if the board/keel is 'up' or partway 'up' you will instead 'skid' a bit instead of grossly heeling over.
RichH is online now
post #13 of 23 Old 10-19-2010
Doesn't sail enough
zedboy's Avatar
Originally Posted by RichH View Post
RDoc----
I don't have much swing-keel experience (tho that may change soon) but raising the keel when you're already feeling overpowered seems ... hair-raising to say the least
Tho what you're saying makes sense if the hull really wants to get up on the plane and the keel drag is causing trouble.
On reflection, in this situation I would ease the vang to allow the top of the sail to twist off and dump air to keep the center of effort low and reduce heeling/broaching moment...
zedboy is offline
post #14 of 23 Old 10-19-2010
RichH's Avatar
For lightweight 'planing hull' boats - Easing off the vang allows the mains'l to grossly "power up" when you try to come come across the wind to 'feather up' ... as sometimes such gusts will have components of backing/veering/backing. etc. wind.... my technique (in lightweight 'planing' boats) is to keep the main a FLAT AS POSSIBLE and 'blade-out' when necessary rather than 'feathering up' ..... to keep the board/keel going in a 'straight line' as much as possible.
If in a lightweight boat and when on a plane, if the boat starts to turn too fast you risk 'tripping over' the board/keel (going somewhat 'sideways') and that can cause a 'dumper'. Lessening the depth of the board/keel allows the boat to skid rather than broaching or 'tripping over the board/keel'.
RichH is online now
post #15 of 23 Old 10-19-2010
Doesn't sail enough
zedboy's Avatar
Hmm, yeah.
What could you do to keep the body of the sail flat but allow the leech to twist and dump air? Keep the vang tight and ease the sheet with the traveller all the way leeward?
zedboy is offline
post #16 of 23 Old 10-19-2010
RichH's Avatar
In higher wind ranges there is usually no need to add twist as the 'gradient wind' is lessened (except for close to the water). Allowing the sail to 'twist' creates a more unstable sail shape with non uniform ability to control. Keeping the sails as flat and 'untwisted' as possible allows FAST and precise control with the sheet or traveller ... enabling one to rapidly and precisely react. When blading-out the luffing happens instantly 'all along the luff' - easy to control; in contrast, a twisted sail will have a progressive luff starting at the top panels and then progressing 'down' along the luff - too damn slow in gusts and will occasionally leave one 'underpowered' ..... at the exact wrong moment.
RichH is online now
post #17 of 23 Old 10-19-2010
T37Chef's Avatar
Nice posts RichH, thanks!
Shawn
T37Chef is online now
post #18 of 23 Old 10-19-2010
Doesn't sail enough
zedboy's Avatar
Yeah thanks Rich
Guys like you are a huge resource for people like me whose limited experience has always stayed on the fair weather/easily controlled end of the spectrum.
zedboy is offline
post #19 of 23 Old 10-19-2010 Thread Starter
TakeFive's Avatar
Thanks for all the comments. I don't have time to respond right now, but I'll reread and post follow-up questions later.
Before things get too far off the wrong tangent, please note that my boat has a fixed lead wing keel, as in "Catalina 250WK" in my signature.
Rick S., Swarthmore, PA
TakeFive is offline
post #20 of 23 Old 10-19-2010
One of None
deniseO30's Avatar
Rick, I had a gust take my boat to starboard so hard I couldn't release the main sheet! I had just rolled in the genny to handkerchief size but I didn't have the sheets tied off. A gust took it back out full, a jib sheet got tangled, making the genny a balloon! The main was still close hauled! My boat heeled awaaaaay over, zipped across the river in just a few seconds. I nearly T-boned a friends Catalina 30 sitting on it's mooring, just as I finally released the main! My O DoomsDay righted herself and turned away just in time... with very little help from me! I don't think the whole incident took more then a minute to happen.
Gusts are not any fun when they are so strong it's dangerous.
when doing light air like 5-8 and gusts of about 8-10 tip the boat it can be fun.. over.. up... over... up...
My last project!
deniseO30 is offline
How they cope with > 25 deg heeling.. Giulietta General Discussion (sailing related) 30 11-11-2008 01:33 AM
Trying to improve in 2 areas: puffs/gusts & gybing merlin2375 General Discussion (sailing related) 13 05-20-2008 05:15 PM
Gusts While Sailing saurav16 Learning to Sail 10 07-03-2007 10:25 PM
Wind gusts capsize boats in Solomons (Baltimore Sun) NewsReader News Feeds 0 03-15-2007 11:15 PM
Winds 15 To 25 Mph. Gusts Up To 35 Mph...increasing To 45 Mph NewsReader Mass Bay Sailors 0 02-04-2007 05:15 PM
