What happens after you fall off your boat. - Page 9 - SailNet Community
 2Likes
post #81 of 108 Old 12-30-2010
Originally Posted by BubbleheadMd View Post
My boat is 25' long, with an 8' beam at the widest point.
You guys say that if your tether and jackline let you fall overboard from the windward side, that they're too long. Geeze, my tether would have to be 1' long to prevent that at some points along the hull, which would be nearly useless.
Advice?
Several months ago someone wrote in these forums he clipped a spare halyard to his harrness. That seems like a prettty good solution to me.
Michael K is offline
post #82 of 108 Old 12-30-2010
pdqaltair's Avatar
Originally Posted by Michael K View Post
Several months ago someone wrote in these forums he clipped a spare halyard to his harness. That seems like a pretty good solution to me.
Please, try things before suggesting them.
* When on the cabin top the length is much different than when at the bow.
* Explain how you get back on, if the boat is heeling 25 degrees.
* On a small boat, this will create a great increase in heeling moment, perhaps leading to a knock-down.
* Unless the halyard has a lot of slack in it, it will make it impossible for the sailor to get low and hold on.
I think there are reasons it is not done.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #83 of 108 Old 12-30-2010
1968 Pearson Wanderer 30
ilikerust's Avatar
Well when we say "spare halyard", are we talking about a line that he sometimes used as a halyard, but also used as a tether line when not in use as a halyard? In which case, we do not assume it was in use as a halyard (i.e., run up to the mast head). I have a couple lines in my lazarette that are or can be used as halyards if needed (e.g., for a spinnaker), but also could be pressed into service as a jack line of sorts.
Or are we indeed talking about an unused halyard that is hanging off the mast? In which case, I agree with pdqaltair that it would not seem to me to provide a very good tether line.
- Bill T.
- Richmond, VA
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
ilikerust is offline
post #84 of 108 Old 12-30-2010
It isn't my idea and I haven't tried this approach yet, but I do believe it may have some merit. I am asssuming that a spare halyard would be paid out so that the end would be just above deck level. If that end were attached to your harness, you may not have total freeedom to move about in a crouched position but you could have greater range by standing a bit more erect; with a second tether restricting your lateral range, you'd still be able to pull yourself back over to the deck even after momentarily hanging out 25 degrees from the mast. Imagine how much easier it would be to pull yourself over than it would be to pull yourself up. Aboard catamarans like what pdq and I have, 25 degrees is a non-issue.
post #85 of 108 Old 12-30-2010
pdqaltair's Avatar
I too have heard this suggested. I even gave it a brief trial on a fair day; perhaps, I though, it would be useful when motoring on flat water but alone on deck. Certainly on my boat, it proved to be a potential hazard.
post #86 of 108 Old 12-30-2010
Glad I found Sailnet
Bene505's Avatar
I think the halyard idea is in addition to the normal tether. Not substituting for it.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #87 of 108 Old 12-30-2010
pdqaltair's Avatar
Regards,
Brad
Try it.
If you place enough slack in the halyard so that it does not pick you off the deck when low at the bow, there will be so much slack whipping around it will catch in the spreaders and around your neck.
Those that suggested it did not think it was a supplement, though your suggestion was hopeful.
post #88 of 108 Old 01-02-2011
ffiill's Avatar
Although 34 foot my boat has a lot of freeboard.I had belived that my stern ladder was quite capable of being used to board the boat from the water,that is until I tried it out whilst on the hard.
No way so I added an extra three steps of stainless tubing which are free to swing.
The advantage of the free swing that is if you are afloat you can get your feet on first rung with a shorter bottom section almost parallel to the water surface without it having to be some 5 foot long below water level and as you pull up body weight straightens the ladder to vertical.
ffiill is offline
post #89 of 108 Old 01-02-2011
Rangernewell's Avatar
Send a message via Yahoo to Rangernewell
On day while on my boat I decided to dive in ....Once in the water I realized the ladder was not out. I just swan around back and climbed up the outboard ....A little stippery but I was able to get back on board fairly easily
Rangernewell is offline
post #90 of 108 Old 01-02-2011
AdamLein's Avatar
On the subject of rope ladders, I made one on the way to a local anchorage recently out of some spare line. At anchor I looped it over a winch and tried using it to climb aboard (with wife in cockpit ready to assist). It was not what I would call easy. Since my center of gravity was not over my foot, my foot would push the ladder under the hull and I would be lying on my back, basically under the boat. It didn't make it any easier that the hull's curvature was so large at the point where I was trying to board.
If you're going to use a rope ladder, or any free-swinging ladder, definitely practice with it first and try it in different places on the hull. Transom or shrouds might have been easier. After a few tries, I figured out what I needed to do to get the ladder to stay more or less vertical, and I wouldn't want to be trying to solve that problem in an emergency.
On another topic, let us not forget that the great singlehanders circumnavigated without a harness and tether, because they felt it was more of a liability than an asset. They just made sure they knew how to move around on their boats safely: "One hand for you, and one for the boat." I'm not advocating that policy, but while you're practicing reboarding with a rope ladder, you might also want to practice duck-walking around on deck, untethered, always with a secure handhold, in whatever conditions you feel appropriate and safe.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
Fall boat haul out - East coast of Canada rikhall General Discussion (sailing related) 2 10-12-2009 09:35 AM
Beaver County man presumed dead after fall from boat in Lake Arthur - Pittsburgh Tribune-Review NewsReader News Feeds 0 05-20-2007 12:15 AM
Avail Next Fall willdadd Crew Wanted/Available 0 02-08-2005 03:36 PM
Eyeglasses fall apart bmcald Gear & Maintenance 7 09-07-2004 10:21 AM
fall sailing N.E. BWithum Crew Wanted/Available 1 08-29-2001 03:51 AM
