Old 10-21-2010
BenMP's Avatar
BenMP is on a distinguished road
Mast hoops
I was wondering the pros and cons of the hoop method of attaching sails to the mast? I have only seen it on older solid wood masted rigs.
Old 10-21-2010
You will then also have noticed that they are only on gaffers that have no spreaders or lower shrouds between the gooseneck and max hoist....
1984 Fast/Nicholson 345
Old 10-21-2010
paul323 is on a distinguished road
I had them on an 18' dingy; worked without a problem, no jamming, quick and easy to rig and haul. Pros and cons - well, sometimes tracks can get a bit sticky, so arguably they have a slight edge; but to be honest (apart from Faster's point about spreaders or lower shrouds) I don't think it is a big deal either way.
Old 10-21-2010
klem is on a distinguished road
As Faster pointed out, you need to have an appropriate rig for them. Here are some pros and cons that I have come across:
Pros:
Very simple, something that you can build yourself.
Can improve air foil shape on a large diameter mast.
Traditional looking.
Can't jam so that you are unable to lower the sail.
They provide some shock absorption in a large gust.
Cons:
You need to get them on which often requires putting them over the masthead. Sometimes you can twist them around the mast but you tend to break a lot doing this.
They need to attach in some way, rivets create stress point and can dig into the mast while lashings need to be redone regularly.
It is one more thing to varnish.
Depending on how you size them they can fail easily.
They can jam on each other/anything sticking out when raising.
Old 10-22-2010
CaptainForce's Avatar
You will then also have noticed that they are only on gaffers .....................
Some might cal it a "gaffer" too, but don't forget the Sliding Gunter Rig. Take care and joy, Aythya crew
Old 10-22-2010
BenMP's Avatar
Thanks for the input it helps a lot.
Old 10-23-2010
St Anna's Avatar
St Anna is on a distinguished road
It is exactly as Klem says. Hard to see in the photo but these are ss - have used bamboo previously
http://i665.photobucket.com/albums/v...a/P4100332.jpg
Old 10-23-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Mast hoops can introduce a fair amount of friction to the hoist and do, eventually, wear on a mast. In daze-of-olde they were eventually replaced with loops of line passed through parrel beads to eliminate friction:
Old 10-23-2010
BenMP's Avatar
So given the choice would you prefer a sail track or hoops?
Old 10-23-2010
It's really a choice of boat/rig first... The hoops(or equivalents) look much more traditional and would be more in keeping with the intent, look and character of these types of boats.
Ultimately I think a "proper" sail track would be more efficient, but that's rarely an issue on boats of these types... and may well spoil the 'look'.
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 08:07 AM
Used mast hoops FrayedKnotArts Gear & Maintenance 0 12-05-2006 02:13 PM
Slow sailing for ex-South Christian hoops stars (The Grand Rapids Press) NewsReader News Feeds 0 11-29-2006 02:15 PM
Mast leaks on keel stepped 52' mast mikeedmo Gear & Maintenance 5 06-27-2006 01:05 PM
