West to East - Page 2 - SailNet Community
post #11 of 21 Old 10-27-2010
Wish I never found SN!
SimonV's Avatar
You will be surprised how quick; cheap and fast damaged and rusty plates can be removed and replaced. I have seen a 40 footer replated from the waterline down to the keel due to severe electrolysis in just over a week.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location SE Asia doing a delivery.
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #12 of 21 Old 10-27-2010 Thread Starter
I was looking for few weeks to find answer. Why not stainless steel?
Could not find it. It could be the price or welding difficulty. Aluminum do not rust, but does crack under stress and electrolysis issue is bigger that in steel.
Steel boat require more maintenance, but then is more safe. I take the safe.
dupek is offline
post #13 of 21 Old 10-27-2010
Stainless steel does not fare well when submersed in water for long periods of time. The lower grades suffer from chloride ION stress corrosion. Even the best grades don't do all that well in salt water.
The best metal to make boat hulls from is a cupro-nickel alloy. It is fairly strong and also does not require anti-fouling paint as a rule. It is rarely used due to the expense of the material. Some commercial ships are made using it to minimize long term maintenance costs. It is also far more resistant to galvanic corrosion issues than aluminum or steel boats are.
sailingdog is offline
post #14 of 21 Old 10-27-2010
Wannabe
Really, your best bet is to have it trucked.
Sailing, you only have 3 options.
Friendly: Down the West coast, through the Panama Canal, and back up through the gulf
Not Friendly: Keep heading south, and around Cape Horn.
Wacky: Just head west out of WA. You'll hit Florida eventually.
If that boat is "the one", then your best bet is to truck it home. Otherwise you are stuck in WA refitting it before a very long sail. Or stuck in TX refitting it before a gulf passage.
dmcMaine is offline
post #15 of 21 Old 10-27-2010 Thread Starter
Just wander, if I isolate the power cords from hull, would that slow down electrolysis process. I saw some of the wiring and the hull was "common ground". I would run heavy water tight isolation.
dupek is offline
post #16 of 21 Old 10-27-2010
AdamLein's Avatar
Do you work? If so, sailing from the west coast to the east coast will be costly in that you will not be earning income for that time period, which will be several months.
s/v Laelia - 1978 Pearson 365 ketch
s/v Essorant - 1972 Catalina 27
AdamLein is offline
post #17 of 21 Old 10-27-2010
Yorksailor's Avatar
Truck it to Texas and sail from there.
Yorksailor is offline
post #18 of 21 Old 10-27-2010
Old Fart
DwayneSpeer's Avatar
northern
There is also the option of going around the north end but it's not easy.
Hey, can one of you guys pass me a crab?
DwayneSpeer is offline
post #19 of 21 Old 10-27-2010
and only open for very limited periods of time....
post #20 of 21 Old 10-27-2010
Try UShip.com
I looked in to these folks when I was considering a Great Lakes boat. You have the opportunity to check their ratings and they bid on the haul job. Looks like you can save big $. Good luck
No personal experience with them. Only know what I read.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
ereiss is offline
West / East, Atlantic, FL- UK, May Douggie Crew Wanted/Available 2 01-04-2005 11:13 AM
North West Passage East to West krissteyn Crew Wanted/Available 0 03-28-2004 04:45 AM
kap horn east - west ocean_lady2003 Cruising & Liveaboard Forum 3 04-04-2003 12:00 PM
West to East across the Pond Michael Carr Seamanship Articles 0 10-31-1997 07:00 PM
West to East across the Pond Michael Carr Cruising Articles 0 10-31-1997 07:00 PM
