Circumnavigation navigating...... - Page 2 - SailNet Community
post #11 of 21 Old 10-28-2010
jackdale's Avatar
Have not done an around the world, but I have done some trips that require a lot of charts.
I keep charts in large plastic "ziplocks" under the berth / settee cushions. Each case is labelled with the general area and the charts included in the case. The chart number is on the lower right while in the case. (I am not that anal at home. )
Many circumnavigators trade charts while in sailing "crossroads."
jackdale is offline
post #12 of 21 Old 10-28-2010
tommays's Avatar
Well
My favorite grounding was the guys who forgot about Sable Island and went all the way across on one GPS waypoint
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 21 Old 10-28-2010
St Anna's Avatar
Well, a lot, especially those not doing a NON-STOP circumnavigation, will trade charts of where they have been for charts of where they're going when in port. Usually, someone is going where you have been and someone has been where you are going.
Yep. Chart swaps and advice along with a few beers. My Pacific / NZ set has crossed 3 times and is on the way back thanks to St Anna, Wintersea, Rushcutter
St Anna is offline
post #14 of 21 Old 10-28-2010
Omatako's Avatar
SD has it right - the trading of charts is relatively standard. Some though (me included) like to keep all the charts they have used because they provide an excellent record of a voyage in the future. When the memory sags, the charts will refresh.
Just an interesting process that I have used - if you live in or near a port, try making a habit of visiting foreign vessels in the harbour and talk to the second officer or someone in a position of relative authority. Ships are inclined to maintain the latest charts and they will only update charts to a certain extent before replacing them.
Their discarded charts are not only quite well updated but are normally in good shape and can be had for a few dollars. I have done that many times over the years and have more than once swapped several charts for a case of beer!!
I have over the years built up a formidable library of charts, some for places I'll probably never go but then they still have swap value for the future and I got them for a song, so to speak.
Arthur C. Clarke
Omatako is offline
post #15 of 21 Old 10-28-2010
Bristol 45.5 - AiniA
We just added about 130 charts that will take us from Panama to Tonga (and includes many areas that we are not going to use). We are lucky to have a very large chart table drawer - I think we could store 500+ charts there and may have to in the next few years. We are using Raymarine Gold charts for our primary navigation and have paper charts and other electronic charts as back up. I am sort of old-fashioned and very comfortable with paper charts.
Not sure how chart swapping works without a lot of costly shipping since people tend to be going in the same way. We will be taking charts from the US east coast and Eastern Caribbean with us and will keep adding to them as we go.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #16 of 21 Old 10-28-2010
Excellent suggestion from Andre...
sailingdog is offline
post #17 of 21 Old 10-29-2010
ASA and PSIA Instructor
Navigating by GPS is asking for trouble, assuming you don't have an electrical or hardware failure. There are several threads on this board from owners who lost their boats due to relying on a GPS' display of their destination, while ignoring the hazards that might exist before they get there...
sailingfool is offline
post #18 of 21 Old 10-29-2010
Send a message via Skype™ to oceanscapt
Chart swapping is a common practice. The problems arise when the anchorage's going the same way as you but thankfully, that isn't that common. A lot of vessels will carry charts for the leg and some basic charts for the next couple of legs. In an anchorage, they'll post a note or two looking to trade of purchase charts of a particular area.
If I were to be using electronic charts, there are world folios that I'd consider or possibly obtaining chips/discs from other cruisers.
I know of desperate folks that have had photocopies sent to them but the cost of shipping was high. They needed the charts and therefore had no choice.
On my last 8 year cruise, I carried the entire set of charts I needed. They took up about 12" of vertical space on top of the starboard pilot berth, but I was sleeping in the saloon or cockpit most of the time and didn't much mind.
Capt. Douglas Abbott
USCG/MCA IV/C.I./M.I. 500-ton Oceans
PADI MSDT
oceanscapt is offline
post #19 of 21 Old 10-29-2010
Yes - charts are good.
Sure - guys can sail without them.
Notice the little marks on charts indicating shipwrecks.
If you don't want to be one of these marks - get paper charts that matter to you. Yes - cost and storage space is a consideration. It's true that "outdated" stuff can be found - cheap. Unfortunately, ya can't board ships (us) and trade for charts anymore. Still, pros toss good (2nd to latest version) charts. 2nd hand chandlers deal them.
Be happy to create space for the charts you have for your voyage. Know the limitations of deciding to go without large scale stuff. Having options is good .
Carry what applies to a leg of your journey. How many can vary drastically. I've used 40+ for a 800nm trip. Same distance - 1 chart.
Harbor charts only matter if the harbor might matter. Large scale charts of planned stops, possible safe harbors, and unplanned options.
Cruising chart books can be adequate - used properly.
Chartplotters are cool - they do not replace paper! It's not ok to navigate without paper charts.
Which charts to carry is the navigators choice (ok- not always).
Thinking the bad stuff happened because batteries, electronics, software, GPS, lighthouse, etc failed is not an option.
Yah, paper charts are good. Correcting 300 can suck. one of you gets that.
Safe sailing
Max
Maxboatspeed is offline
post #20 of 21 Old 10-29-2010
Omatako's Avatar
Another couple of things that I could mention:
When you are planning a voyage, make sure that firstly, you have charts not only for your chosen stops but far any and possibly all the bolt-holes along the route. You never know where you may have to go in an emergency and when things are already stressed and dangerous the last thing you need is to arrive at a strange coastline sans charts.
Secondly, another must in my view is the appropriate coastal pilots for coastlines along your route because charts provide limited info regarding sneaking into hidey-holes when ducking for cover whereas pilots provide tiny and valuable detail.
I speak of this from bitter experience.
Arthur C. Clarke
Omatako is offline
Navigating locks GoodOldBoat Good Old Boat 21 05-04-2015 11:52 AM
Navigating with an iPhone? PaulSail51 General Discussion (sailing related) 42 11-27-2008 12:12 PM
navigating a squall bkw Learning to Sail 53 03-08-2008 04:25 PM
Navigating with Radar Jim Sexton Seamanship Articles 0 03-29-2002 07:00 PM
Navigating from Block Island Bruce Caldwell Cruising Articles 0 08-21-2000 08:00 PM
