Forespar Lightning Master™(Static Dissipater) Who's been hit with one? - Page 3 - SailNet Community
View Poll Results: Has your boat ever been hit by lightning with a Forespar Lightning Master™ installed?
Yes 1 16.67%
No 5 83.33%
Voters: 6. You may not vote on this poll
post #21 of 30 Old 11-03-2010
Maine Sail's Avatar
Having a boat nearby with a taller mast is not a solution. Ask Maine Sail. Basically, LIGHTNING DOES WHAT IT WANTS... anything you do to try and change its behavior is mainly wishful thinking and will make you feel better, but really not help at all.
Yep we have over 1200 boats in our mooring field and perhaps 90-95% of them are sailboats. Most are 30' or bigger. The same day my boat was hit a teeny tiny Cal 22 was also hit and had holes blown through it. It had one of the shortests masts in the mooring field and perhaps the most minimal or "systems" and was in a cluster of boats all over 30' whose masts were significantly taller. My boat neighbor to one side has a mast 8 feet taller than me and the other closest guy has one 10 feet taller. The guy behind me with the "lighning attractor" has a mast 2' shorter than me and was still hit. My spar is properly grounded yet my mast was not hit and my boat took and indirect hit through the ground side of the system.
My friend Kim's boat, a large racer with Carbon spar and fuzzy attractor, was also hit and the spar had to be sent out for a full inspection and repair (DO NOT GET HIT WITH A CARBON SPAR $$$$$$$$!). Lightning does what it wants to.
The only believers in "bottle brushes", "fuzzy disipators" or "lightning attractors" are those who have not YET been hit. They ALWAYS believe they have not been hit because of it UNTIL they get hit. At that point they may or may not realize it is junk science based in nothing but unproven theory.
Lightning will hit what it wants, when it wants to, snake oil devices or not..
Oh and NONE of my fuses blew. The lightning came though the ground side and the voltage is so high it often completely ignores fuses and jumps across them before blowing them. My boat was the fourth one it two weeks the surveyor had inspected due to lightning. All were different but most all had virtually no blown fuses. I have seen lightning blow a seacock off a thru-hull and vaporize bilge water enough to blow the cabin sole boards off the bilge.
The ONLY science that I see working for lightning strikes is the science of adequate INSURANCE coverage!!!!!!!
Originally Posted by Forespar
The "study" is the fact that since the early 1990's we have sold about10,000 units worldwide. Of these we have had reported strikes totaling 4. Not bad empirical data. Of these strikes damage was minimal. Isolated to EMP induced damage rather than direct strike damage.
Even with this said, Forespar does not claim that this device is 100%
effective. No one can make that claim.
Consider that the Boat US foundation puts your odds of getting hit at 1.2 per 1000 that make it 12 per 10,000 Forespar is claiming 4 per 10,000. This means the devices barely work if you even trust what Forespar is saying. We can also guess that there were also some hits on boats where they owner never knew who made the dissipator because it was on the boat when they bough it.. How could you report it to Forespar if you did not know who made it. Food for thought and more food for my opinion of them as "junk science"..!
From Boat US:
"You Can Run, But You Can’t Hide
Volumes have been written about methods to mitigate damage or even avert a lightning strike. Lightning, however, doesn’t seem to read them. As an example, one boat, fitted with a popular “fuzzy” static dissipater at the top of the mast was struck twice in one year; ironically, the second time the bolt hit the dissipater even though the VHF antenna right next to it was higher (claim #0308082)."
______
-Maine Sail / CS-36T
Maine Sail is offline
post #22 of 30 Old 11-03-2010
For any nerds out there with the endurance to read it, here's a recent paper. My offer stands to put lightning rods on my neighbor's house. Works best in a tightly packed neighborhood .
http://www.bentham.org/open/jlr/articles/V001/1JLR.pdf
capecodda is offline
post #23 of 30 Old 11-03-2010
Best Looking MALE Mod
Cruisingdad's Avatar
You guys are really screwing up my business idea. I already bought the tin foil. SD put a order in for the Reynolds-Undies. I hope he doesn read Maine's comments.
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #24 of 30 Old 11-03-2010
Cruisingdad,
Put my order in too! Never let science get in the way. I believe in covering all my er...bases.
Good stuff
post #25 of 30 Old 11-03-2010
Trust me, we had little to do with your business ideas being screwed up...
sailingdog is offline
post #26 of 30 Old 11-04-2010
scurvy dog
delan's Avatar
I swear by my "bottle brush"
Between West End and Bimini, I had 3 strikes so close I could swear I could smell the electricity, I know that doesn't make sense, but for sure, it's how it seemed, but no direct hit.
Back at the dock in Miami, in the past four years, three other boats next to me, all with smaller masts, one a powerboat, have been struck and all electronics destroyed, the powerboat had half it's breakers welded shut.
It could be luck, bit I'll stick with what's working.
The chainplates and backstay are all grounded, and I have a fairly massive stainless centerboard, that's part of the grounding system
Restauranteur
Mako 236
Shamrock 26
Schucker 44 Cutter
Dyer Dhow
delan is offline
post #27 of 30 Old 11-04-2010
Boasun's Avatar
With all the years that I have sailed and all the boats & ships I have been on, I've only been struck once by lightening.
It hit the SSB antenna blew out the Antenna coupler and the SSB before it went to ground through the SSB's grounding strap. All that was worth saving was the carasses of those two elements.
This was a steel hulled boat so we weren't worried about anything. All the other electronics were operational and not harmed.
But all the time I have been out there and had lightening strikes all around and that was the only one.
But if you put a lightening rod or one of those bottle brushes on your mast. Be damn sure that it is well grounded to a solid grounding plate on the keel. That way you won't blow out your electronics. Unless the hit is on an antenna that is.
In fact have everything well grounded to that grounding plate
Note: a Steel or alunimum hull don't need that plate. But wood and Fiberglass hulls do....
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #28 of 30 Old 11-05-2010 Thread Starter
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald's Avatar
delan:
We also have never been hit. But similar to your 'smelling' the lightning (ozone?) we have felt it - with our hair feeling like it's standing on end. I've heard some say that their fillings in their teeth hurt.
capecodda:
Attempted to read your link - it's more about buildings than boats. When I got to the part with the calculus, I poured myself a generous helping of rum and plodded on...whew! Don't remember the rest of it.
boasun:
Agree with grounding well to protect crew and passengers. However, with a direct hit, I doubt that grounding well will protect your electronics. While they are probably protected from a direct hit (a sure-fire electronics fryer) it's the EMP (electro magnetic pulse) which generates high amounts of voltages in the circuits of electronics which fry them. The only thing that will protect the electronics is avoiding the direct hit (with the grounding) accompanied by a Faraday cage to protect from the EMP. Though the effectiveness of the Faraday cage is still in question as well as the need for grounding and ferrous (not stainless or aluminum or the newly patented tinfoil scheme, er, business venture by cruisingdad.)
Lots of good information here, thanks! But the most convincing will be statistics. I have so far not come up with any hard information and I've looked at boat insurance companies, which aren't publishing if they have collected data. I need to contact them directly, but they don't seem to offer any way to contact them unless you want to buy insurance. (Boy, what a surprise.)
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
LarryandSusanMacDonald is offline
post #29 of 30 Old 11-05-2010
I don't pass this info along as my own...caveats apply, etc... this is foolproof:
Buy an expensive (the more expensive the better the result) #1 iron at a golf pro shop. Hoist it to the masthead on a halyard in such a way that it can be seen easily. that's all there is to it!
thekeip is offline
post #30 of 30 Old 11-05-2010 Thread Starter
Doesn't it have to be connected to a golfer?
Forespar Marelon winches bobmcgov Gear & Maintenance 6 08-09-2010 11:08 PM
Static Electricity? NCountry General Discussion (sailing related) 7 07-28-2010 08:51 PM
Forespar TruPlug kwaltersmi Gear & Maintenance 4 04-22-2010 04:45 PM
Connect to The server static.youchoose.net adru Announcements and Suggestions Box 4 06-30-2009 07:37 AM
Link 10 Static ereiss Electrical Systems 1 06-17-2009 06:07 PM
