Old 11-03-2010
Hydrotherapist is on a distinguished road
Marine AC in TX
I have a heat/cool system on my sailboat located in South TX on the Gulf. It's winter now and I want to know if I should shut the system down or keep it running. (I'm thinking algae and barnacles may develop if I don't keep it cycling... or even if I do???) ???
Old 11-03-2010
Allanbc's Avatar
Allanbc is on a distinguished road
I have my boat in Port Aransas. I leave mine off when I am not on the boat.
I don't do any special winterizing as we have a lovely year-round sailing season. If it gets really cold, I have a boat safe heater for the engine compartment.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 11-03-2010
Marine AC in TX again...
Thanks for that info... I am new to TX and thought I needed to keep the AC cycling all the time or face corrosion and barnacles in the thru hull lines??? If I can shut it off during the winter, that would be great!!!
Old 11-03-2010
Allanbc's Avatar
You can close off the through hull and not really worry about it. Make sure you periodically clean out the strainer.
Where is your boat located?
New to marine networking...NMEA vs. Garmin marine Network? sapster77 Electronics 6 11-10-2009 04:56 AM
West Marine Peel Away vs. Peel Away Marine Strip 2 SeanC. Gear & Maintenance 0 03-24-2006 03:28 PM
Marine VHF pixurman Learning to Sail 6 05-17-2002 08:12 PM
US Marine 30 mercator Boat Review and Purchase Forum 0 02-21-2002 12:14 AM
