11-05-2010
Originally Posted by kwaltersmi
Just to re-emphasize, I think you should at the very least upsize your anchor if you plan to sleep while on the hook. As BlueWaterOnly points out and the Dashaw's have written (paraphrasing): "If people laugh at the enormous size of you're anchor while carrying it down the dock to your boat, you've got the right size." If you're just using the 20lbs CQR as a picnic hook then you're probably fine. And don't forget, proper scope is just as important as the anchor and chain.
And Just to re-re-emphasize; Along with adding more chain, You could double up your anchors in tandum, with a fathom or two of chain between them. This will increase the lighter anchors holding power.
Also you do have winches on board. You can always take the anchor rode to the halyard winch on the keel stepped mast or to one of the sheeting winches on the Cockpit rail, your choice. But when that chain comes aboard you WILL want to have some chaffing gear laid down on your decks.
1600 Ton Master, 2nd Mate Unlimited Tonnage
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Maritime Instructor To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
S/V Rapture
