11-08-2010
Setup time for trailer trash
What is it about s bigger boat that takes so long to set it up. Currently I am sailing a 17 footer. Setup takes about 45 minutes, from the time I pull into the Marina, till the time the boat is in the water. While I understand stepping the mast on a larger boat may take more playing around, especially if it is tall and heavy, but with some of the rigging I've seen for stepping the mast looks pretty simple, such that it should not add that much more time. I had a guy tell me it takes around 4 hours to set up his Mac. I just can't imagine what would take that long. What else is there to do on those larger boats that takes so long? Comparing 2 boats, same brand, one at 21' and the other 23', a comment that an owner made was the 23' you do not want to trailer sail it very often, because it takes a long time to setup.
I'm thinking of getting a bigger boat, but still trailer sailing, so I'm trying to understand what I am in for. What can be done to make the set up time reasonable. Are the things that take time, conquerable?
Has anyone built a pole/crane into their trailer to step the mast? I'm not talking a short pulling system, but a long beam/crane type setup.
Dave
AFC 17' 2+2
Hobie 14'
Sunfish project boat
Sailing a large boat on a small lake is very tacky.
