why daily weather reports? - SailNet Community
Blogs
Old 05-11-2003
svORCA is on a distinguished road
does a sailor "really" need a weather fax or other weather reports on a regular basis? if i do my research, before i depart on a 21 day cruise to hawaii, do i need weather reports during that 21 days?
Old 05-11-2003
Jeff_H's Avatar
Super Moderator
At the risk of being seen as a wise guy, if you have to ask that question, then perhaps you are not ready to make that passage. Sailors have made many a safe passage in the years before radios and weather fax''s so while it is possible for you to make the trip without weather updates it is probably a really bad idea. When you think that major storm systems can move across the eastern Pacific in as little a week to 10 days from the time that they form, I would suggest that having a heads up on what is happening would be a good idea. While the local weather underway may not be terribly accurate or germane knowing what to expect should help you make decisions about routing, sleep rationing and sail choices. I don''t think that you need a weather fax but I would suggest that you should have a radio capable of recieving long distance weather transmissions on board.
COLD WEATHER SAILING!!!! coriffithq General Discussion (sailing related) 8 09-30-2007 08:45 PM
Weather SURPRISE out at SEA coriffithq Learning to Sail 14 08-26-2003 05:47 PM
preping for heavy weather jbarros Seamanship 7 05-02-2003 08:32 AM
How to?? get weather reports via sat email and sat phone at silentfaith General Discussion (sailing related) 0 01-16-2002 03:54 PM
Noaa Marine Weather Images Ocean-Pro Cruising & Liveaboard Forum 1 01-04-2002 07:14 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
