Old 11-13-2010
micheck is on a distinguished road
Rigging questions
I need to replace the running/standing rigging for a Cal 29. Does anyone who has a similar boat have recommendations for material and size for [present]:
halyards [3/8" dacron]
sheets [3/8" dacron]
vang [1/4" braided nylon]
running back stay [3/8" dacron]
anchor rode (35# Plow - chain & rope) [1/4" HT chain 50 feet - 200 feet 1/2" 3-ply nylon]
standing rigging [3/8" SS 1x19]
also
From whom do you buy your line?
Thanks - Charles
Old 11-13-2010
Today there are low stretch ropes that work better for halyards than good old dacron yachtbraid.. Sta-set and Sta-set X come to mind.. at a price, mind you.
Halyards at 3/8 are probably OK, the new line is plenty strong. For sheets yachtbraid would be fine, but I'd upsize to 1/2 or so to be easier to hand. Nylon has no place on running rigging.
I don't believe I've seen runners used on a Cal 29.. but again a low stretch line would be better.
Your anchor setup might benefit from a chain up-size, and another hundred feet of line rode wouldn't hurt, depending on your common anchoring situation.
I'd be very surprised if your standing rigging is actually 3/8" That's pretty heavy duty for a boat that size. Best bet here is to take/send the existing bits to a rigger for replacement. A member here has provided good service to others, so maybe send Knothead a PM.
Any marine retailer will have the line you need.. if you have several in your area just price compare..
Good luck!
1984 Fast/Nicholson 345
Old 11-13-2010
nickmerc's Avatar
nickmerc is on a distinguished road
You may also want to configure Colligo Marine for the standing rigging. It is a new synthetic material instead of stainless. I just tried it for replacing my lifelines. I was able to do all of the splices myself and have been very happy with it. When it comes time to change my standing rigging I plan to go with synthetic.
The benefits I see are light weight, easy DIY, no corrosion, and I like how it looks on my boat.
I am not affiliated, just a happy early adopter and satisfied customer.
________
California Dispensary
Old 11-13-2010
Interesting... how does the cost compare? is this similar to PBO?
EDIT: checked out their site.. looks like price is close to even, weight not even close...
Old 11-14-2010
nickmerc's Avatar
The one detractor, for some people, is the increased windage. Some wire sizes need to be replaced with larger diameter dux.
________
Vaporizers
Old 11-14-2010
tommays's Avatar
The original was
Headstay 7/32
Backstay 3/16
Bridles 5/32
Uppers 3/16
Fwd lowers 5/32
Aft lowers 5/32
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 11-14-2010
Thanks Tommays... that's more like what I was expecting to see.
Old 11-14-2010
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
Actually it isn't the windage of using the new spectra 900... It is lighter than the steel rigging it is replacing and you will have less weight going up your mast. That leds to a tad more stability, which is a good thing.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 11-14-2010
tommays's Avatar
Well
Except for those GIANT termination fittings that have the required LARGE required radius so the line does not break and there rather costly
Photobucket
And the ones i have seen require custom work on the spreaders
Its a product with a small market the serious race boats go with with PBO or Carbon as the fittings have been made with low windage and the big company's stand behind the stuff
For a normal boat if you look at the total cost its much more money than stainless with no real advantage
Tommays
Northport NY
Old 11-15-2010
QuickMick's Avatar
QuickMick is on a distinguished road
ive had really good luck with these guys:
Discount Rope and Line items - Get great deals on Marine, Industrial items on eBay Stores!
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Junk/Sampan rigging vs. Cat rigging ClaireFAISE General Discussion (sailing related) 10 09-21-2010 08:59 PM
Cat 22 rigging questions radioguy Gear & Maintenance 5 08-08-2010 12:35 PM
Rigging Questions davidpm Gear & Maintenance 12 04-08-2010 01:37 PM
Standing Rigging: Some Questions sailjunkie Gear & Maintenance 7 03-24-2010 05:51 PM
26X RIGGING ESPERANZA2 Learning to Sail 1 05-09-2004 10:32 AM
