-   -   smallest dinghy for use with 9.9hp motor (http://www.sailnet.com/forums/general-discussion-sailing-related/69899-smallest-dinghy-use-9-9hp-motor.html)
Incantation 11-14-2010 11:01 PM
Hey guys,
Wondering what the smallest dinghy size is that will accomodate a 9.9hp motor.. I want to use it for my Catalina 30 but I am thinking the dinghy will likely be too big. I have a mount/lift on the transom where I can mount the motor and then lower it to the dinghy if I need to use it.. otherwise I was hoping to store the dinghy on the bow.. or possibly mount it aft.
Greenflash35 11-15-2010 04:46 AM
Inflatables are light and easy to stow.
tommays 11-15-2010 06:31 AM
You will have to look at the dingys as there are two issues
1. The dingys HP rating
2. The transome weight rating which has become and issue withe 4stroke motors
PorFin 11-15-2010 08:23 AM
Originally Posted by Incantation (Post 666759)
Hey guys,
Incantation,
If I'm reading between the lines correctly, you already have a 9.9hp outboard and are trying to fit a dinghy to both it and your C30.
How about you go about it another way. Find a dinghy that you are comfortable with in terms of size, weight, handling, etc. Then size your outboard to the dinghy -- if the 9.9 works, great! If not, then swap or sell your 9.9 for an outboard that will fit. I think this approach will be a more suitable one that will pay off in the long run.
EJO 11-15-2010 08:37 AM
I thought most 10 ft (3.1 m) inflatable can handle a 10 HP. But 9.9 sounds like a 4 stroke which are heavier and as previously mentioned watch the transom weight. I don't think you could find a hard shell dinghy capable of what a inflatable could handle. Also a RIB inflatable wouldn't be as easy to hoist on board. Deflate it and it will easily fit the fore-deck.
Skipper E-J
S/V “SAILMATES” 1973 IRWIN 32 CLASSIC
jrd22 11-15-2010 09:28 AM
9.9 is pretty big for most small (8-9') inflatables. We have an air floor 10+' with an 8hp two stroke and it's almost too fast. I tried a 9.8 on it and it's scary. Most small inflatables that would be sized right for your 30' boat would only need 3-6hp IMO.
Incantation 11-15-2010 06:51 PM
Ok well i'll look to either swap for dinghy+motor or just sell it and buy em.. thanks :)
