11-20-2010
Steve,
If you have no power and a fuse or breaker is not blowing then you don't have a short, you have an open circuit. The positive or the negative wire can be open. All you need to troubleshoot this is a $10 voltmeter. I'd get a piece of wire and hook it directly to the main ground bar, and connect one lead of the voltmeter to it. Then I'd use the other lead to go looking for positive voltage at the affected light fixtures. A voltmeter is extremely sensitive compared to a light bulb. So if you find a plus voltage at a fixture that isn't working you have probably found a poor connection. Test at each fixture, if they are wired in series you will probably find a bad connection at one of them. You will also want to test the ground side of the fixtures as well, by connecting the wire and meter to the plus terminal on battery.
Gary H. Lucas
