Old 11-23-2010
tcastrosantos is on a distinguished road
Novice question
I am looking into getting a small-ish boat in the 26-ft range (the Chrysler C-26 has come to my attention) and am wondering what folkls might suggest for a boat that must sit on tidal flats. Specifically, are swing keels ever used in this way, or is it too much torque on the keel and a recipe for disaster?
Old 11-23-2010
jackdale's Avatar
jackdale will become famous soon enough
You should probably look at a bilge keel. There are some in the size range in which you are interested.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 11-23-2010
Thanks Jackdale--
I've been thinking along those lines as well. Any suggestions as to make?
Old 11-23-2010
IIRC, that's actually a TWIN KEEL, not a bilge keel. Westerly, Tylercraft and a few others made them. Most are relatively small boat though.
Old 11-23-2010
jackdale's Avatar
I have read good things about the Golden Hind 26. It is a British design, but there is at least one in North America. Gary Geddes, author of Sailing Home, has (had) one.
GRP yacht, Golden Hind 26 ft Golden Hind, Bilge keel, sloop yacht, Golden Hind For Sale - Ł16,950 - Maldon, Essex - Boatshop24.co.uk
Old 11-23-2010
Jackdale—
IIRC, the Golden Hinds were also built in the USA by CE Ryder, out of Rhode Island.
Old 11-23-2010
Izzy1414's Avatar
..........huh?..
Izzy1414 is on a distinguished road
The bilge keel is designed with your environmental parameters in mind. Definitely worth a look if that is a priority for you. To your specific question on swing keels .... any retractable keel boat that is designed to beach will allow it to sit "relatively" upright when high and dry. Failure to raise the rudder and keel (whether it's a swing keel, dagger board or other) before hand will cause you problems though.
S/V Boccata d'Aria
I'm not sure what Dickens are, but I think they may be important and I sure as hell don't want them scared out of me.......Izzy
Old 11-23-2010
Great feedback, one and all. Now could someone please explain to me the difference between bilge and twin keels? Also any pics of the Ryders would be interesting--that Golden Hind is georgeous
Old 11-23-2010
The main difference is that bilge keels are generally flat plates, where twin keels are usually shaped foils. Bilge keels are often added to boats to improve their stability, but not really designed to resist leeway, and may be very shallow in depth. In fact, some sailboats with a keel may have bilge keels added to help provide additional stability. This photo is an extreme example of a shallow bilge keel.
Given your interest in learning more about them, I'd recommend you read the article located HERE.
Old 11-23-2010
TheWhiteRabbit's Avatar
TheWhiteRabbit is on a distinguished road
Jackdale; do you know what kindda boat this is a picture of? That thing is BadAzz!
Detailed question / novice / appreciate any feedback Lynniepoo87 Cruising & Liveaboard Forum 14 10-22-2010 02:14 PM
novice question seas/ swells/winds and kids.. pleasure sailing ONLY... Motherof3 General Discussion (sailing related) 58 08-16-2010 09:21 PM
Novice compounding/waxing question... WhatTheFoley Gear & Maintenance 5 08-05-2009 01:06 AM
Question: As a novice...What can I learn from these differences in specs? souljour2000 General Discussion (sailing related) 4 07-13-2008 12:35 PM
Naive novice question re: buying a boat Conny Boat Review and Purchase Forum 12 07-21-2003 09:45 PM
