11-26-2010
Color is a consideration, and darker colors will tend to cause the boat to heat up and act as a moisture pump. As the boat heats up during the day, the air inside, being warmer can hold more moisture. Then, as the boat cools off at night, the moisture condenses out inside the boat. In very, very cold climes, this isn't as much of a problem, since there isn't as much available moisture in the air, but you're not that far north, so I'd recommend going with the heaviest, thickest, light-colored tarp you can get. :-)
