- Quick Menu
11-30-2010
Best Looking Moderator
West Marine/General Tether Caution
HI Everyone. We bought the WM (not made by them, of course) Tethers a while back very similar to this product:
WEST MARINE Standard Safety Tether at West Marine
Except with the Wichard clips on the Jackline side. For those who do not know (or those that do) they are not cheap (as in inexpensive). If you look closely, you will see that the lanyard for the PFD side is connected via a small ring. The point of this is that if you fall overboard, you can easily find the lanyard and pull (even when under strain) and it will release you from the boat versus drowning.
On BOTH of the tethers we have purchased, these have failed. The first, when pulling on the lanyard, the lanyard pulled off the ring and the ring stayed attached making it difficult to disconnect from the Tether. The second failed but the ring came off and the damn pin took off in the cockpit at night (but luckily we found it).
I am writing this caution because either incident could be a serious safety issue - especially the lanyard that did not come loose when pulled. I suspect that if that had happened while being dragged by the boat, a person could have drowned.
I am not dogging the product. It is heavy made and should be a part of every offshore sailors inventory. But please check and or replace the rings to something more sturdy that will take use. I am afraid that those of you that have this product or similar and do not use them much might not notice the failure until too late.
Brian
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
11-30-2010
S/V Lilo, Islander 32
Thanks Brian, this is excellent information. The tethers on my boat came with the boat, and I do not know what brand. I have looked them over for other possible issues, wear, broken stitching, corrosion, etc, but never really looked at the rings for the shackle pull. You bet I will now.
Thanks,
Bryan
S/V Lilo
1964 Islander 32
Saint Helens, OR
11-30-2010
lubricating the pin will help prevent problems.
11-30-2010
I believe those tethers have been recalled. I will try to find my recall notice.
I have an older tether from WM on which the rings were welded.
Jack
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
11-30-2010
11-30-2010
Originally Posted by jackdale
That's them... at least close. I never heard the recall.
However, my issue is that the rings fail because they are undersized and not really made to handle that type of load. A solid, welded ring would be the answer, as mentioned above.
Brian
Com-Pac 16
11-30-2010
Hey Dog -
Lubricating the pin will not fix this problem. The action is smooth and believe me, that is one piece of equipment I keep nicely protected when not in use. The problem is the rings are undersized and really not the right use for that load.
Brian
Com-Pac 16
11-30-2010
I correct myself. The recall mentioned in the PS is EXACTLY what my problem is. It is a ring malfunction.
Thanks Jack!!!! They're going back.
Brian
Com-Pac 16
11-30-2010
I worked for west marine for about five years. I'm in an out of the store from time to time now seeing as I still work in the boating industry, namely with sailboats. I know there was a mass recall of one of their particular brands of tethers. I've done a lot of single handed cruising on my boat and always use jack-lines and a tether but have been disappointed with the quality of some of the tethers out there, not to mention the price they cost. In regards to the Westmarine tether I would check with your local store, I'm almost positive it's been recalled, and if I missed that comment from someone above already stating so, I apologize for reposting it.
As for tethers though I got sick and tired of looking for a reliable one, so I made one myself using some rock climbing shackles I had and high strength double brade line. I spliced the two ends with the shackles and now have had the tether for almost 5 years, with no problems at all. I only did this because I've been splicing lines professionally, if you're not sure you can do a good job, get a local rigger to do it for you. Just some food for thought...
~Good sailing~
11-30-2010
We have 5 of these - 4 singles and 1 double. 3 of the singles have been replaced under the recall. I have made 4 trips to WM to exchange the double and last single. They never have any doubles in stock and always promise to have them in next month. This has been going on since August.
Yesterday there were no tethers in stock at all. So may have to work this through the mail.
Kirk
L440 Ainulindale
| Thread Tools |
Search this Thread |
