Old 12-05-2010
chrisncate's Avatar
Mango intolerant
chrisncate is on a distinguished road
How long can you idle a diesel for the hydronic heat?
How long can you idle a diesel for the hydronic heat? I am thinking about going at the heating issue at anchor in two ways, one being a hydronic heater and the other being a solid fuel bulkhead heater.
The thought being that the wood heater could suffice most of the time, but for the really cold nights and coldest part of winter, a hydronic heater that runs off the engine heat for real btu's. Can you safely idle a Yanmar 2GMF20 all night long occasionally, or even consistently for a month or longer?
A hydronic heater that puts out 40k btus is under $500 from defender, and the small solid fuel newport is probably about $550 with all the hardware needed.
For an Alberg 30 btw..
Old 12-05-2010
centaursailor's Avatar
Senior in age only!!!
centaursailor is on a distinguished road
Exclamation
Can,t beleive this a serious enquiry from an enviromental perspective.
Running any disel engin for prolonged periods with little or no load is not recomended.
Bore glazing would damage the engin and is very costly to repair.
The low levels of fuel efficiency for running the engin to produce heat which is a by-product of propulsion must be staggering. There are several disel cabin heaters that run independent of the engin and have relativly high efficiency ratings
Any alternative must be a better proposition.
Brian
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
Old 12-05-2010
LakeSuperiorGeezer's Avatar
LakeSuperiorGeezer is on a distinguished road
Unlike gasoline engines, diesels are very efficient at idle. Not enough heat is generated to bring the engine up to temperature. I am saying this because I know at rest areas where trucks park, it is known fact that you cannot heat a cab with an idling engine. Combustion is going to be incomplete and you can get slobbering; also you can get plugged exhaust ports in the engine.
Old 12-05-2010
ffiill's Avatar
ffiill is on a distinguished road
Confused-surely hydronic heaters are the likes of Webasto Thermotop?
which is a minature version of your keroscene fired central heating boiler or in a more basic form the pressurised keroscene/diesel stove.
Fuel oil is pumped under pressure through a jet and ignited by a spark plug.There are the versions which then provide blown air but in the Hydronic version it circulates engine cooling water from an indirect cooled engine through minature radiators with or without fan blowers.
Primarily was designed to keep automobiles and trucks warm overnight in arctic conditions without having to plug into a mains water heater.
Having said all of this I find my gas cooker loaded with a couple of dense concrete building blocks very effective.
If I were however living aboard I would go for the Davys Hotpot solid fuel stove made over here in UK but I believe marketed world wide.A lovely marine minature solid fuel stove which lives up to its name.
I live with a multifuel cast iron box stove at home and guarantee there is still nothing like them to space heat whether by wood;coal or smokeless fuel..
Old 12-05-2010
bacampbe is on a distinguished road
Interesting. Can you elaborate?
s/v Dancing Days
Beneteau 31
Lewisville Lake, TX
Old 12-05-2010
Our last boat had a fan-equipped heating coil in the engine FWC circuit - similar to whats known as a 'bus heater' and pretty much what's in any vehicle for interior heat. These will only provide heat when the engine is running at temp.
There are, of course, diesel fired hydronic heating systems as you describe that are independant of the engine for a heat source. Sounds like the OP has the former.
I'm not sure the glazing issue (often debated, btw) is as much of a concern at low revs that at high revs unloaded, but as mentioned from an environmental angle (not just smell/emissions, but noise and vibration) running the engine solely for that purpose doesn't make much sense. I suspect it would be a rather expensive method as well, if you crunched all the numbers (added hours, maintenance, fuel etc)
For a bit more money the Dickinson Propane fireplaces are the deal, perfect for an Alberg 30, with it's limited interior volume, fully vented and safe to use and if you already have propane on board for cooking, the fuel system is already there. Also, the package includes everything you need, including the deck vent/intake, dual flue and mounting plate. Be sure to price any other system on the same basis.
http://www.dickinsonmarine.com/Specs...9-P12-2008.pdf
1984 Fast/Nicholson 345
Old 12-05-2010
jrd22's Avatar
Courtney the Dancer
Unfortunately, as others have said, you won't get much heat out of the bus heater you are talking about unless you run the engine rpm's high enough to open the thermostats. In cold weather you would probably have to put the transmission in gear and run the engine at full cruise speed to generate enough heat. Been there, done that (one very cold night in our crab boat).
Faster's suggestion about the propane Dickinson is a good way to go.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 12-05-2010
dupek is on a distinguished road
Idle
As truck driver, I can said that you can idle for any prolonged time you want and does heat cabin ( as someone stated opposite) in cold night. The only requirement is "bump" the RPM. On truck normal RPM is 550, but need to be bump to 750-800. On small engine, I would bump 50 rpm and should work as long as you have a fuel. The problem arise from ecological point of view. Air and surrounding pollution. At low rpm, some unburnt fuel will go to water. No good.
LP gas generator would be the answer, but it is expensive.
I would choose LP gen to heat up the boat with ceramic heaters.
Old 12-05-2010
P35juniper is on a distinguished road
If you can find a way to load you engine, say add a generator to it, for a 2GM20F it would be about 8KW, draw about 6KW as electric heat and recover the heat from the engine, its called combined heat and power, this setup is very efficient, diesels combust very efficient when loaded, better then 90% burn, you get about 20% rotation, the rest being heat, so with a CHP unit it is better then most house heaters,
next question, do you want to run up 720 hours amonth on your engine?
Old 12-05-2010
ffiill's Avatar
Got the idea from what over here in UK are called night storage heaters-at night electric element draws energy from cheap rate electricity and heats up a load of concrete blocks inside heater. During day heat is released.
So same concept but you heat up blocks and cabin space in your oven during day and let them release heat with no danger of carbon monoxide at night when its at its coldest.
If you regularly use oven its a problem!
Hydronic Heater Install jonfreeman Gear & Maintenance 17 11-13-2011 02:56 PM
Hydronic Heating - ProHeat X45?? BELLATRIX1965 Gear & Maintenance 1 09-27-2010 11:03 PM
Diesel Stalls at Idle jfmid Diesel Engine Forum 15 06-22-2010 06:25 AM
Detroit Diesel 8V71TI - Long distance cruising? phlebas Diesel Engine Forum 12 03-05-2010 12:39 AM
Help finding tubestack/heat exchanger parts for a BMC 1.5 Marine Diesel dbrimm Gear & Maintenance 3 02-09-2009 04:57 PM
