Old 12-07-2010
micheck is on a distinguished road
Need a raw water manifold
Before we get too far - I HATE BRONZE - it is a religious conviction and is not debatable - now --- I have a 1.25 inch thru-hull system with a Marleon ball valve. From that I plan to go to a seawater strainer and then to a manifold that sends some of the water to the head intake, the sink/anchor spray pressure system and the engine cooling. The best I've come up with is two inline PVC Tees with glued-in nipples. Any other solutions - I HATE BRONZE.
Charles
Old 12-08-2010
I would highly recommend having the engine intake on a separate through-hull or adding seacocks to the lines coming off the manifold so that you can shut off the head and sink/anchor washdown systems independently of the engine cooling water.
Why not use a proper manifold box, preferably with a clear top to allow visual inspection.
Old 12-08-2010
RichH's Avatar
RichH will become famous soon enough
Unless carefully sized/engineered, an 'inlet' manifold serving several functions can easily be well below the flow requirements of the total requirements ... and 'choke'/cavitate. To do this correctly, you MUST calculate (then test) ALL the 'stack up' of pressure drops at full flow for all the 'branches'. Unless you do this carefully, you risk 'turbulent flow' and the *whole* system will not operate correctly .... the first component/branch to be possibly damaged will be the engine with a 'severely restricted' raw water flow. This is 'especially' pertinent for when in very WARM water so to prevent the inlet water from potentially 'flashing'/boiling when severe pump(s) vacuum is applied when the total 'demand' is the greatest and is becoming 'turbulent'. As S'dog stated, the engine should 'always' be on a totally SEPARATE and independent inlet.
Let me attempt to change your 'bronze apostasy' - There is absolutely nothing 'wrong' with bronze for seawater service - TRUE bronze, not the cheap 'red-brass' that is foisted off to marine consumers as 'bronze'. RedBrass is a 'bronze' that is loaded with zinc to make the bronze 'easily machinable' - can become a boats 'zinc anode' when the other boat zincs fail. "Good Bronze" is a royal bitch to machine and therefore is 'not cheap' because it takes special expertise and specialized tooling to machine it. One of the most stable bronzes for seawater service is Nickle-Aluminum-Bronze (bring your mortgage application with you when you buy NiAlBronze).
Marelon is a nylon co-polymer, Nylon readily 'hydrolyses' (comes apart) in long term water contact; I would rate 'marelon' one step above red brass for seawater service.
Old 12-08-2010
Thank you both - I will re-think and do as you advised
need exhaust manifold for my W30 captaineasy Gear & Maintenance 0 10-06-2009 05:08 PM
Need W 30 exhaust manifold captaineasy Diesel Engine Forum 0 10-06-2009 03:47 PM
Yanmar 3GM30 salt water in intake manifold Peregrina Gear & Maintenance 18 04-06-2008 07:10 PM
Yanmar 3GM30 Salt water in intake manifold Peregrina SailNet Website Technical Support 0 03-31-2008 02:51 PM
MD11C Exhaust Manifold takwita Gear & Maintenance 1 11-10-2004 01:35 PM
