Old 12-12-2010
JoeAntz is on a distinguished road
Protecting lines from weather
My Ericson is wintering in an industrial area so I want to remove or pull the lines inside my mast so the stay as clean as possible. How can I attach messenger lines to my mast lines so they won't come undone or foul in the masthead sheaves.
If left to my own solution, I would butt a slightly smaller diameter line tied with clove hitches and then tape over. Or is the a better way?
Old 12-12-2010
marianclaire is on a distinguished road
I butt the two lines then use SS wire to connect them and a tape cover. The wire bites in better than string and can be twisted tight. Has worked every time so far. Dan S/V Marian Claire
Old 12-12-2010
You can also sew the two lines together and then tape over the join...
Old 12-12-2010
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
When changing out old flag halyards; I've long spliced the new and old together and haul the new up with the old hoist (3 strand line). And afterwards I would cut the old ratty hoist off and splice the jewelry to the new.
This is the only time that I have used the long splice. Which is something you can't use if you have solid braid line. Thus you may have to sew or staple the new & old together. So it is the material of your halyards that will force the method of connecting them.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 12-12-2010
genieskip is on a distinguished road
All my halyards have either a whipping or an eye splice at the end (the end away from the shackle). You can put in (or have put in by a rigger) an eye splice that is made without the core. that kind of eye splice is no larger in diameter than the line and therefore can easily go through blocks. Tie a bowline around the splice or whipping and pull the halyard down and the messenger up. Presto!.
genieskip
Northeast
J40
1991
Old 12-12-2010
Sabreman's Avatar
Sabreman will become famous soon enough
I butt the ends of my halyards to an 1/8" nylon messenger line and duct tape the two together with a spiral winding from the halyard to the messenger and back again. I use a strip about 8"x1/2" of good duct tape. This makes for 2 layers. I roll the taping between my palms to smooth the transition. I've also lightly tapered all my halyards at the ends to make the transitions easier. We've only lost lines in the mast twice. Once when I still used masking tape instead of duct tape. The other time was when I was lazy and temporarily taped 2 messenger lines together to make them longer; I forgot to untape them, they got wet, and separated 6 months later. IMO, there is no need to stitch the lines together.
We remove all our running rigging each season and wash the lines in laundry detergent, flaking the rinsed lines in the garage for a week or so to dry. After about 6 years, we end-for-end the lines and get another 6 years out of the lines. Depending on your season, you get about double the life out of your lines (in the Chesapeake, we get about 6 month seasons).
This has been our process for 23 years.......
Sabre 38 "Victoria"
Old 12-12-2010
waterdog52 is on a distinguished road
Butt the lines a close as possible. I used 20 pound monofilament fishing line. Clove hitches and and over hand knots and mutliple passes buit a 60-80 pound splice. Tape as need with good duct tape or elelctical tape like scotch brand 33. then pull close to bow or stern as posible to increase the angle the splice enter the and leaves the sheave. good luck
Old 12-12-2010
Sabreman's Avatar
I forgot to mention that when pulling lines, do not pull too hard. If they don't run free, then reverse and try again. I learned that lesson the hard way.
Sabre 38 "Victoria"
Waterproofing/protecting wood wind_magic Gear & Maintenance 3 05-31-2010 02:49 PM
Protecting PVC Dinghy? night0wl Gear & Maintenance 8 03-18-2009 10:21 PM
Protecting the environment from oil spills. flyingwelshman Off Topic 0 03-17-2008 05:15 PM
Protecting Ourselves from the Elements Joy Smith Seamanship Articles 0 06-08-2004 08:00 PM
Protecting Ourselves from the Elements Joy Smith Her Sailnet Articles 0 06-08-2004 08:00 PM
