Rebedding leaking lexan ports - Page 2 - SailNet Community
 1Likes
post #11 of 13 Old 11-17-2003
Any suggestions for getting the ports out in the first place? Mine leak, but they seem firmly in place.
carib99 is offline
post #12 of 13 Old 11-17-2003
There is a product called "release" which, when applied to old caulk, tends to help it come off. Appears to be at least somewhat effective on silicone and polysulfide. There is another liquid for polyurethanes (5200 and 4200), called "debond". Available in WM. Not perfect, but it does help. OTOH, when I replaced (not "rebedded", but "replaced") my plastic portlights, I literally cut them in pieces and cut them out of the fiberglass with a reciprocating saw--would have been 10 years getting them out any other way--but of course the plastic portlights were then just small pieces and not reusable.
Peace.
mcain is offline
post #13 of 13 Old 12-01-2003
We got a flexible lenght of braided wire fed up through one of the leaking areas. Used it like a cable saw. Just wrap each end about a piece of wood dowel, with one person above and one below. Saw away and it follows the opening.
Worked well to remove 6 large deadlights.
paulmcquillan is offline
ugly ports KenD Gear & Maintenance 4 02-08-2003 06:38 PM
ports on hull/flush deck problem prrthead Boat Review and Purchase Forum 1 04-04-2002 09:17 AM
replacing fixed ports captainal Gear & Maintenance 4 03-19-2001 05:34 PM
Around of Mediterranean. Marinas and Ports. okoulaga Cruising & Liveaboard Forum 0 02-28-2001 06:11 AM
Around of Mediterranean. Marinas and Ports. okoulaga General Discussion (sailing related) 0 02-28-2001 06:01 AM
