Old 12-15-2010
blr972 is on a distinguished road
Small boat and a hammock?
Hey guys, I'm more of a reader and less of a poster but anyways...I have an Ensenada 20 and ever since my girlfriend saw a hammock out on deck on a larger boat she wants one on mine. The Ensenada has a pretty stout mast and the stays are pretty good size so...if I could find the space, would the mast/boom/stays hold the weight of a hammock? I see them all the time in other boats but they usually have more than 10ft on me so the mast and everything is much bigger.
Can I make her happy and get a hammock?
Thanks
Old 12-15-2010
ShamsB is on a distinguished road
I'm not sure about what the mast and stays on a boat that size could take but would make sure if you do try to remember the more sag in the hammock the less pull on the points its attached to.
Old 12-16-2010
jrd22's Avatar
Courtney the Dancer
If the mast and headstay can take the forces from the sails, they should be able to handle your girlfriends weight. Do you have enough distance between headstay and mast for a hammock?
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 12-16-2010
QuickMick's Avatar
QuickMick is on a distinguished road
how big is your GF? j/k...lol
maybe try one of these if your concerned about your rig?
Capacious Portable Hammock | Sports | SkyMall
go to skymall and check 'em out... just search hammocks... the things you will read on the tarmac at LAX....
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 12-16-2010
JKCatalina310's Avatar
JKCatalina310 is on a distinguished road
Between the head stay and the mast
We had a hammock on our C&C 24. I would attach the head end to the mast with some old jib sheet line, using the boom connection to stop the line from sliding down the mast. The other end I would connect to the furled head sail with a carabiner. It worked great.
Good luck.
“Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.” -Mark Twain
Old 12-16-2010
Might be better off with a hanging chair, since you can hoist it aloft with a halyard. Point loading the stays or shrouds is not a good idea.
Old 12-16-2010
She is 125lbs so I guess I should be good there. I think I have a hammock that will work between the forestay and mast. I guess I just won't jump on it too at my 220lbs. Thanks guys, that'll make her happy to know.
Old 12-16-2010
funjohnson's Avatar
A New Adventurer
funjohnson is on a distinguished road
Maybe you could try a tracker (click here) to eliminate the point loading on the headsail? If it can hold a spinnaker on a furled sail, I'm sure it can support 125 pounds!
1989 Sabre 34II Targa
mjsailing.com
Old 12-16-2010
ftldiver's Avatar
ftldiver is on a distinguished road
someone needs to say it....
Old 12-16-2010
justified is on a distinguished road
when cruising the ICW we would set one up for my niece. take two lines from to the bow rails and then the spin or spare jib halyard and raise up to the level you need to accommodate her pull on gravity. Enjoy a great book!
Peter
Best way to rig a hammock n0w0rries General Discussion (sailing related) 7 04-30-2010 11:40 AM
Hammock on my 25' sloop? kwaltersmi Gear & Maintenance 25 07-16-2009 04:13 AM
Hammock Netting ... wind_magic Gear & Maintenance 8 06-22-2009 07:53 PM
Rigging for a Hammock offline2004 General Discussion (sailing related) 2 07-31-2007 11:17 AM
Infant Hammock offline2004 herSailNet 4 05-19-2006 06:39 AM
