Pearson Wanderer Centerboard Cable - Page 2 - SailNet Community
post #11 of 13 Old 01-12-2011
BTW, StaSet is a just a polyester double braid and not really a high tech line.
Originally Posted by keyman17 View Post
In 09 (not '08) I replaced my cb cable for the first time. In the water. I had nothing to pull the new cable through with, so I got some cheap wire cable from the hardware store, duct taped the end tapered, and it just shoved right through the entire pathway. This cable was slightly oversized for stiffness.
Next, I generously taped the upper end of this cable to some high tech rope ( might have been stay set) and pulled that through. I tied just a bowline around a thimble and bolted it to the cb. Attaching the upper end required removing the end cap of the roller and using a stopper knot where it passed through the hole in the drum.
I hope to replace it again this year when it gets a little warmer. Other than having to keep the cb trunk clear of barnacles, I've had no problem with the rope cable.
On a related topic, I learned recently that if a cb cable ever breaks on you, it can be wedged up with almost any wood. Wooden clothes pins work great. No need to use a rope bridle tied to the deck to hold it up. What a neat discovery.
sailingdog is offline
post #12 of 13 Old 02-24-2011 Thread Starter
Fireriders
Send a message via AIM to Cottonmouth
should have thought to ask before but what diameter cable is recommended for this type of job. Thanks again for all the help.
Cottonmouth is offline
post #13 of 13 Old 02-24-2011
What diameter is the steel cable? What size are the sheaves?
Centerboard cable/rope? P35juniper Pearson 12 12-20-2013 08:55 AM
Pearson Wanderer 30 vs Cheoy Lee Offshore 31 jpmpac Cruising & Liveaboard Forum 1 08-26-2010 04:57 PM
Pearson 30 Wanderer vs Tartan 3000 jpmpac Cruising & Liveaboard Forum 6 05-23-2010 03:04 PM
Pearson Wanderer aris Boat Review and Purchase Forum 2 07-31-2007 01:23 PM
Pearson 35 Centerboard Cable lazypointer Gear & Maintenance 0 12-04-2000 06:37 PM
