12-19-2010
Originally Posted by bubb2
Anything better than tell tales?
Experience.
As a former full time sailing instructor I always wished to cut the tell tails off the boats, but the owner of the sailing school would not let me. Knowing wind direction and how it is flowing over the sails is a learned skill. Tell tails allow you to cheat the learning curve. Knowing the wind direction should come as second nature and you can speed up the learning curve by every time you exit you home or car that you spend 15 sec's with your eyes closed feeling which direction the breeze is coming from. Before long you will know with out thinking about it where the wind is.
When it comes to sail trim, Experience also is your best tool. If you sail the same boat long enough you can feel by the "pull' of the sheets if you have the boat in trim or not, just by feel. I understand using tell tails when racing, but for the average cruiser they make us lazy.
This also known as sailing by the seat of your pants. And that skill comes after a lot of experience on the water.
1600 Ton Master, 2nd Mate Unlimited Tonnage
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Maritime Instructor To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
S/V Rapture
