01-01-2011
I would first ask myself what I was going to realistically want to do over the next couple of years. As a gross generalization, small sailing clubs seem to teach on single sail dinghies (not all), which is probably the best way to get started. If you plan to sail a very small boat for the next couple of years, that's a good way to start.
On the other hand, if you want to be out there with the offshore cruisers and will be buying your own 30 footer, I would suggest a fast track cruising course. Don't over estimate your skills upon completion, but you will be jump started into the sport for sure. Those schools often use boats that have been designed to demonstrate and instruct all the sail systems of larger, typically sloop rigged, sailboats. I've seen my wife go from zero experience to a fairly good offshore mate in six months.
Don't tell her I called her the mate.
Since you have an internet browser, just do a search for sailing schools and start there. If you can afford the time and admission, I think learning in warm weather over the winter is the way to go. Some courses are as short as a week with zero prior experience. It will be sailing season shortly after you acquire your new skills and you're ready to get out there.
