Stanchions - Yes or No? - Page 2 - SailNet Community
post #11 of 21 Old 01-10-2011
I don't have lifelines or stanchions for the most part on my boat. The boat came with lifelines that mount on the amas, but they aren't generally used since the ama has a FOOT-HIGH bulwark outboard of the ama's deck. The newer models of the Telstar 28 don't even have the mounting points for the stanchions, since they were generally causes for leaking into the amas.
sailingdog is offline
post #12 of 21 Old 01-10-2011
tommays's Avatar
I do a lot of overnight races and cant picture draging sails around and changing them without lifelines as a guide
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 21 Old 01-10-2011
g0twind's Avatar
PY23 here, no lifelines. It came with the brackets but not the stantions/lines. I day sail on Lake Ontario and always wear a jacket on the foredeck.
I feel that the side decks are too narrow to have stantions so I will not be putting any on.
1974 Paceship PY23 "Barely Awake"
Hull # 001
g0twind is offline
post #14 of 21 Old 01-10-2011
I have a Catalina 30 and have the standard stanchions and lifelines. I tell anyone going forward to hold on the the lifelines while moving. This keeps their body low and prevents them from loosing their balance. I would not go out on the ocean without them.
s/v Odyssey
Catalina 30
glassdad is offline
post #15 of 21 Old 01-10-2011
Barquito
Barquito's Avatar
I think the sidedecks on boats around 22' are too small to have high enough lifelines. Smaller boats are also not as likely to go as far offshore. My C22 didn't have lifelines. Some did. Certainly on a C30 however.
Barquito is online now
post #16 of 21 Old 01-10-2011
Once known as Hartley18
Classic30's Avatar
Dock
FWIW, my 30' "Classic" boat, like many others of similar vintage, doesn't have lifelines although I have the option to fit them for going off-shore. Instead it has a 4" ankle-high bulwark fitted right around the deck and I'd suggest that, given adequate hand-holds, that the bulwark gives at least an identical feeling of security (if not more so) than having lifelines.
If you do have lifelines fitted, aside from the "going overboard" feeling*, although, yes, they DO help hold the headsail on deck when dropped, having to skirt the thing on every tack - meaning someone going forward hence increased possiblity of them actually going overboard - is a major pain in the butt. JMO..
(*) Most yachts less than 60' LOA don't have very wide decks. When walking along a deck with lifelines fitted you can feel them pushing against your legs, which is why people feel they might go overboard. This is because the lower body is constrained inboard whilst the uppper body can move outboard making you feel that if you lost your balance due to some unexpected movement, you'll be swimming. With a bulwark or similar *high* toerail to ankle height and NO lifelines, the feeling of security increases, simply because your legs are free to move to help you balance naturally, whilst the bulwark prevents your feet from sliding on a sloping deck.
By comparision, I often race in an Adams 10 which has only a small toe-rail (and in some places nothing at all!). Having nothing to stop you going feet-first on a sloping deck makes for a HUGE feeling of insecurity in a seaway compared to having lifelines.
In summary: IMHO, for sailing on enclosed waters on a small boat, optimum feeling of security and practicality is found with an ankle-height bulwark and hand-holds along the side of the cabin and center foredeck. Next best is lifelines and worst is nothing at all..
Off-shore in a blow, you need lifelines to keep EVERYTHING on deck (not just the crew) and that's really all there is to it.
Hope that helps.
Classic30 is offline
post #17 of 21 Old 01-10-2011
bljones's Avatar
I like my lifelines and stanchions- it gives me a place to hang stuff.
bljones is offline
post #18 of 21 Old 01-10-2011
Classic30's Avatar
Dock
Very true. ..and somewhere to tie off the awning ..and somewhere to mount the BBQ.
post #19 of 21 Old 01-10-2011
jackdale's Avatar
jackdale is offline
post #20 of 21 Old 01-10-2011
There were no lifelines on the Dyer dinghy I learn to sail on as a kid. Ironically, I was much more likely to fall out of it than I am my current boat. Still, lifelines are mandatory for me now.
Minnewaska is offline
C&C stanchions Kiltmadoc C & C 6 07-05-2010 06:19 PM
Stanchions tampahokie Gear & Maintenance 2 07-31-2007 12:09 AM
stanchions ddilman General Discussion (sailing related) 3 04-27-2006 01:27 PM
Stanchions RobGallagher Gear & Maintenance 7 11-25-2001 05:09 AM
lifeline stanchions bernie-t Gear & Maintenance 4 02-03-2001 12:46 PM
