01-11-2011
Originally Posted by YeahJohn
You can clean the speed transducer while the boat is in the water from the top access point? Thanks for the help.
John
Yes you can. On newer boats there is a baffle that stifles some of the water flow. Regardless, after you unscrew and pull the transducer, put the replacement plug in and and tighten it. You will get water, but your bilge pump will handle it.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
