01-17-2011
Morgan 33 O.I. Perryville
If the entire display is blinking the probable cause is the display itself. This could be something as simple as a bad solder joint, or the display could be in the early stages of failing.
If the depth reading is blinking, but the rest of the display is still fine, the likely cause is the transducer--but not always. It could also be the connector to the display, which could be experiencing some corrosion problems. Ordinary contact cleaner sprayed on the connector's pins and socket, then dried with canned air should solve this problem. If not, the problem is obviously more serious in nature.
Transducers rarely fail--especially those that are mounted inside the boat's hull and the signal fired through the fiberglass hull. Through-hull transducers, however, are more subject to damage and can ultimately fail because they're exposed to the elements. Failures can also be cause by having the bottom of the hull sanded when the person doing the sanding inadvertently sands the face of the transducer. I saw this happen on at least two occasions and the damage was merely painted over with bottom paint.
Good Luck,
Gary
