Old 01-16-2011
Aussie Yachties
rossmcdonald is on a distinguished road
Asymetrical winches for right handed users.
We have owned a C & C 36' built in 1984 for 12 months.
Does anyone know if it is common for yachts to be specifically built for right handed people??? Strange question? Read on.
Until we started to do measurements for a new dodger, we had never noticed that Qualita appears to have been built specifically for a right handed person!! Really facinating. When operating the winches, it feels comfortable. Everything in the right place - plenty of elbow room etc. We found that the Port side winch is located approx 150 mm further astern than the stbd one. (We decided that this was to save whacking your elbows on the coach house rear, or falling backwards into the saloon when operating the Port winch). The Stbd one is able to be located further forward on the gunwhales as there is plenty of room in the cockpit to operate it. Very logical. Weird we had never noticed that they are not symetrically placed on the gunwhale. (Try pulling a few imaginary sheets to see what I mean - which way your body faces & where your elbows are depending whether operating Port or Stbd winch).
I would love to know if this winch set up is common with other yachts or just Qualita. (I am thick skinned so you can tell me I am an idiot & all yachts are like that!)
Does anyone out there know if this is common>?
Cathy & Ross McDonald
Old 01-16-2011
According to this factory image, these boats were produced with the winches aligned side-to-side. I have to say that any boat we've owned has been the same.
Could it have been done avoid chafe on the coaming edge near the port winch (which leads to the inboard side of the drum)? This is a issue on a lot of boats.
1984 Fast/Nicholson 345
Old 01-16-2011
CaptainForce's Avatar
My winches are in symmetrical allignment, but I am aware that I face forward when operating my port winch and I face aft when operating my starboard winch. I never noticed this before this post, Thanks! Take care and joy, Aythya crew
Old 01-17-2011
paulk's Avatar
paulk is on a distinguished road
The fact that the line wraps around the winch clockwise also affects winch and cleat placement. You want to have a clear lead to & from it, and the correct angle vis-a-vis the cleat.
Old 01-17-2011
john1066 is on a distinguished road
Wow, that's attention to detail. I've never noticed this on any boat I've sailed. I'll bet the distance that one winch is offset is equal to the diameter of the drum, so that the sheet exits the winch at the same point on each side.
I can't imagine what the benefit is. If it's to avoid some obstruction when winching, as you suggest, why not move both winches back?
John
Old 01-17-2011
It may not have anything to do with "handedness" but everything to do with the physical limitations of the winches and getting a fair lead to them. Without photos it is hard to say why the change was made.
Old 01-17-2011
Aussie Yachties
Asymetrical winches
Thanks for the replies - you have all made it more complicated! Thanks Faster for the drawings, we have none, where did you get them? Our boat appears identical to the drawings - apart from the winches. The drawings appear to show that the smaller winch is forward of the larger one, whereas our boat is the other way around. They have not been built like that to avoid chafe, there is plenty of space on the coaming. The angle to wrap the line around both winches is perfect. Also...I had a look at some photos & they show that the Port winches have the cleat forward of the winch, whilst the Stbd winches have the cleats to the rear! CaptainForce mentioned the way the body is aligned whilst operating the winches & if you can visualise it, it all makes sense.
If I can work out how to get some photos up, I will.
Ross & Cathy
M 34 Asymetrical Spinaker cboudart Morgan 1 09-25-2008 05:15 PM
drifter vs asymetrical spin mrkeith General Discussion (sailing related) 8 03-17-2007 11:48 AM
Asymetrical VS symetrical eda0457 Racing 6 02-07-2003 06:46 AM
making & installing an asymetrical sprit Shannara Gear & Maintenance 4 11-17-2002 11:03 PM
Asymetrical spinnakers Irwin32 Gear & Maintenance 3 04-30-2002 02:15 PM
