Webcam to watch your boat -- Done! And how-to. - Page 4 - SailNet Community
 5Likes
post #31 of 56 Old 01-25-2011
tommays's Avatar
Bene
I gotta believe that of those 22 valves you cant need more than 4 or 5 to use the boat in winter and the others could be shut and winterized
Whats really needed beyond the motor and a 5 gallon bucket to pee in during the really cold times
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #32 of 56 Old 01-25-2011 Thread Starter
Glad I found Sailnet
Bene505's Avatar
Thanks SD for that clarification.
Tom -- I have all of them closed except for the engine raw water, dripless shaft, and one other one that is stubborn. I didn't antifreeze any of them because it's salt water in them and they are below the water line.
I don't like the smell of antifreeze, but perhaps I should go around and put antifreeze in them?
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #33 of 56 Old 01-25-2011
Bene—
Given the depth of this cold snap, I'd dump some antifreeze around them just in case.
sailingdog is offline
post #34 of 56 Old 01-25-2011 Thread Starter
Bene505's Avatar
Bene—
Put antifreeze in them, right?
OK.
Regards,
Brad
Bene505 is offline
post #35 of 56 Old 01-25-2011
tommays's Avatar
I guess there not all created equal BUT mine have drain plugs you can remove when the valve is closed to get the water out of the ball area
Tommays
Northport NY
tommays is offline
post #36 of 56 Old 01-25-2011
Back to your little heater, I also have one I use, it has a thermostat and a low setting. Yours looks to be sitting on some carpet, so unless it is asbestos, it might be better to use another surface. Mine is on a large tempered glass cutting board with insulated feet.
baboon is offline
post #37 of 56 Old 01-26-2011 Thread Starter
Bene505's Avatar
Baboon,
I want the rug to stop the heater from walking, especially over to a wall where it could heat the wood intensely. The fan does not really vibrate the heater, but I feel more comfortable knowing that it will be exactly where I put it.
All -- the heater is now on low. By the way, with it on high, the plug was not hot and the circuit breaker was not hot.
Regards,
Brad
Bene505 is offline
post #38 of 56 Old 01-26-2011
A silicone trivet mat would do much the same and present far less a fire risk. Just saying...
Originally Posted by Bene505 View Post
Baboon,
Regards,
Brad
post #39 of 56 Old 01-26-2011
I like everything about this set up except that space heater. Experience has taught me that those little boxes always fail and despite all the safety switches, I think that they are a fire hazard when left unattended. I use one of those thermostat controlled oil filled electric heaters when I will not be in the same room with the heater. Yes they are big and ugly, but have an adjustable thermostat and 3 power settings. I've used one in my cold bathroom for 5 years. If you need a fan to move hot air around, buy a fan. It will be much less susceptible to clogging than the little one in the heater.
glmark is offline
post #40 of 56 Old 01-26-2011 Thread Starter
Bene505's Avatar
An alternative solution. Love it. Thanks.
By the way, Hugo and I checked some of the thru-hulls last night. They were at 34.6 degrees on a very cold night. Seems the ice eater has warm-ish water flowing past the boat.
We did not go sailing -- the fairway was solid ice. 4 inches thick right behind the boat. Guess I need an outside webcam so I know when the next sailing session can be.
Regards,
Brad
Bene505 is offline
Storm watch… when to pull boat? talismansigns General Discussion (sailing related) 14 09-04-2008 08:00 PM
Watch Out! punjabi Learning to Sail 8 10-23-2007 11:50 AM
Which Watch is Best? Dobbs Davis Seamanship Articles 0 07-23-2002 08:00 PM
