3rd Reef in Main? - Page 3 - SailNet Community
post #21 of 27 Old 01-17-2011
Originally Posted by labatt View Post
We have a third reef... North of Annapolis installed it for us and it was a regular thing for them. Ours gives us 45% of the main (approximately). We use two line reefing for all three of our reefs, led back to the cockpit. We have a heavy Schaefer cheek block on the boom with oversized screws, and we said "screw weight aloft" and went with a heavy running line for the third reef. We've actually never used it (when we were in 70kts of wind a couple of years ago we reefed to our second reef and ran in front - in retrospect, a third reef would have been a smart idea as we exceeded 9kts of boatspeed on a vessel with a theoretical maximum of 7kts - and that was with very little wave action i.e. we weren't surfing down a wave). Anyway, we do like to know it's there.
Ya think???
sailingdog is offline
post #22 of 27 Old 01-17-2011
Yorksailor's Avatar
I have 4 reefs but only have 1, 2 and 3 rigged and when I was out in 45 knots gusting 55 knots I was wishing I had it rigged as the third reef that gets me down to 30% of the main's size was too much sail.
My 4th reefs substitutes for a storm trysail but my sail is 13 oz cloth and can take the load. Off-shore I will rig reefs 2,3 and 4.
Phil
Yorksailor is offline
post #23 of 27 Old 01-17-2011 Thread Starter
Now that I am up to speed on reefing for gale force winds, can someone answer a more perplexing question?
HOW do I get this forum to send me email notifications about new posts?
As far as I can deduce, I am set up to get them, but I don't get them.
mainemandean is offline
post #24 of 27 Old 01-17-2011
Looking into it!
Faster is offline
post #25 of 27 Old 01-17-2011
Wind force is sail area x speed squared. So if you reef normally at 20 by 30 you need to reduce the sail area by half. If 25 by 35. I am not sure why Sailing dog says the reefed sail will often have less force on it than the unreefed sail would have normally.
Say you normally reef at 20 knots. At 30 you need have half the area or a bit less. Comparing both wind speeds at say 5 and 10 knots less you will have less force on the reefed sail than on an unreefed sail at 20 knots but quite a bit more than at 10-15 knots. At 35 however even with a 50% reef you will have a third more than at 30.
The traditional 37.5% less luff length gives a sail area reduction of about 60% if my arithmetic is right because the foot also reduces.
I estimate that the normal second reef only extends the wind range by 6 knots or so. The advantage of a dedicated sail if you need it is that it can be much stronger, because gusts will tend to quite high and the sea state would tend to reduce the ability to handle them in the usual ways.
chris_gee is offline
post #26 of 27 Old 01-17-2011
Again, it all depends on how deep the reefs are and what wind speeds you put the different reefs in.
post #27 of 27 Old 01-18-2011
48' wood S&S yawl
cormeum's Avatar
We have 3 reefs. Our set up is to have a seperate cheek block and bail for each line. we also have a seperate rope clutch for each line but a common winch on the boom to snug the reef up. the bail is (almost) under the corresponding cringle but the cheek block is set aft to provide tension.
We also have one reef for the mizzen.
We do also have a trysail track for a really teeny trysail (equivalent of a 4th reef). I'd think that we'd only use it for over 60 kts. or very high wind heaving to. - haven't had to (fortunately)
That said, I'd probably go with stays'l and reefed mizzen if I wanted to heave to in high winds.
"Never attribute to malice that which can be adequately explained by stupidity." - Robert A.Heinlein
cormeum is offline
Main Sail question, No reef points? DulceSuerna General Discussion (sailing related) 8 11-30-2010 02:20 PM
How loose is your main sheet while raising the main? legarots General Discussion (sailing related) 33 06-24-2009 05:26 AM
To reef or not to reef, that is the question blackpearlsailing General Discussion (sailing related) 12 05-28-2008 08:46 PM
My first Reef... Stevyboy General Discussion (sailing related) 11 04-08-2008 01:45 PM
best way to reef a main doubleplay Seamanship & Navigation 10 03-27-2004 03:55 AM
