Old 01-20-2011
hackandhue is on a distinguished road
Question Poles Shifting
I was reading a lot of the poles shifting, and the ramifications of this. (tampa had to change the headings on its runway). I assume that this means some sailing charts are going to need to be updated? Just curious what you guys thing. "True North" and "Magnetic North" should have changed, correct?
Magnetic Poles Shifting | Seagull Striker's Going Sailing
Old 01-20-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
The earth's magnetic axis is ALWAYS moving around a bit. Note that the compass rose on a chart always gives the annual increase or decrease.
Old 01-20-2011
jackdale's Avatar
jackdale will become famous soon enough
More than just a bit.
The Canadian government has made several measurements since, which show that the North Magnetic Pole is moving continually northwestward. In 1996 an expedition certified its location by magnetometer and theodolite at 78°35.7′N 104°11.9′W.[8] Its estimated 2005 position was 82.7°N 114.4°W, to the west of Ellesmere Island in Canada.[9] During the 20th century it moved 1100 km, and since 1970 its rate of motion has accelerated from 9 km/year to aproximately 41 km/year, or 1.3 mm/sec (2001–2003 average; see also Polar drift). If it maintained its present speed and direction it would reach Siberia in about 50 years, but it is expected to veer from its present course and slow its rate of motion.
Canada has been very magnanimous in letting other countries use the magnetic pole. Russia may not be so willing.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 01-20-2011
QuickMick's Avatar
QuickMick is on a distinguished road
Well, the stars wont shift.
as to SlowButSteady, good article here:
NASA - Earth's Inconstant Magnetic Field
as to cataclysmic pole shift... heck i didnt think nostradamus was right and i dont believe in the the aztec/mayan doomsday calender either.
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 01-20-2011
Senior Slacker
When I said "a bit", I was referring to the annual change. I'm well aware that the earth's mag field moves, and even "flips" from time to time. Those magnetic "stripes" in the link QM posted were part of the early proof of plate tectonics (and happen to be the subject of a lecture in the Intro to Oceanography course I teach from time to time). You might also note that the movement of the magnetic axis also changes the compass "dip" (or magnetic inclination/declination) at any particular point on the earth's surface. This three-dimensionality of the magnetic field has all sorts of biological and paleontological consequences, in addition to screwing up the compasses of vessels that travel between the northern and southern hemispheres.
Old 01-20-2011
so unless we get a pole flip, which *could* happen next year according to NASA, than what is really significant enough to matter? I imagine now with GPS it matters less because you can just update your software, or it will do so automatically.
Old 01-20-2011
jackdale's Avatar
We still teach how get a fix using a handbearing compass. Variation matters.
We also teach deviation, but for some crews that is a part of their nature.
Old 01-20-2011
centaursailor's Avatar
Senior in age only!!!
centaursailor is on a distinguished road
Smile
The stars don,t shift, well not very much anyway. The earth spins tho so the stars appear to revolve aroung the North star as the night hours tick by. Just dont follow any one other than the pole star for long periods or you will be off course.
Happy sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
Old 01-20-2011
QuickMick's Avatar
isnt that what i said?
Quinn McColly
Yacht Broker
Old 01-20-2011
Smile
Fair enough.
A4: Stalling when shifting from neutral CLucas Atomic 4 8 08-13-2009 12:31 PM
mast shifting sailboatman35 Sailboat Design and Construction 2 05-27-2008 09:05 AM
Land masses shifting ianhlnd Off Topic 13 09-22-2007 11:37 PM
shifting cable repair pamelajy15 Newport 2 01-12-2007 04:39 PM
Shifting gears at the helm ccboston Seamanship 3 03-02-2004 07:03 PM
