Boat fires - Page 2 - SailNet Community
post #11 of 11 Old 01-24-2011
However, this really isn't a solution. The problem was in the wiring, not at the outlet, and this would have done nothing to prevent the fire in the OP.
The real key is proper maintenance and regular inspection.
The one location where the thermal circuit protection really makes sense is the main shorepower inlet socket...since that is the most exposed and generally receives a lot of wear and tear. Smartplug has a new shorepower inlet that is thermally protected and the pin design is much better than the old 30 amp twist-lock connectors that are the current standard.
I can buy an industrial Meltric load break receptable and cord end for less, and it is far more robust with solid silver alloy connections rated for full load break arcing without damage.
Gary H. Lucas
GaryHLucas is offline
Coast Guard Finds Missing Boat, Still Searching For Other Boat - WSOCtv.com NewsReader News Feeds 0 05-11-2007 04:15 PM
Strong winds sweep Southern California, fan fires - The Desert Sun NewsReader News Feeds 0 04-19-2007 08:15 AM
Strong winds sweep Southern California, fan fires - San Diego Union Tribune NewsReader News Feeds 0 04-18-2007 11:15 PM
