01-31-2011
The reason is you've probably got a "compact" bowl, rather than a standard one. The compact bowls are really small, but are the only way the head will fit in the space allotted on many boats. If you've got the room for it, you can probably remove the bowl and put a standard size bowl, which is only a tiny bit smaller than a household toilet seat. Some of the new electric heads have a "comfort" size bowl, which is effectively a full-size bowl and seat.
Losing weight would help...
