Like Tree1Likes
Old 02-02-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
Loose Foot Main sail vs Foot Bolt Rope in boom Track
I have the choice for my new main. Have always had the traditional bolt rope foot on my main going into the boom track,
What do you have?
Advantages? Disadvantages?
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 02-02-2011
capngregg's Avatar
Shaken-not Stirred
capngregg is on a distinguished road
Cool Mainsail choices
My little SC 22 had a bolt rope main when I first got it and it sailed okay. At that time my only method of reefing the main was the original roller reefing boom. This always felt very cumbersome to me and is definitely not recommended when the wind is way ahead of you reefing, especially if you're singlehanding.
When I purchased my new main I had double reef points put in and I went "loose footed". I also installed a boom vang and a topping lift. The boat seems to point better (not that this is any kind of a high performance ride) and I can obtain superior sail shape on any point of sail.
I much prefer the loose footed sail over the bolt rope but I don't really think there is too much difference that can be realized on a small boat. On your boat it may make a large difference though. I used to crew on several high performance race boats and we always used loose footed mains.
Gregg
Jeaux-Jeaux likes this.
Opportunity is missed by most people because it is dressed in overalls and looks like work.
T.A.E.
Old 02-02-2011
Sabreman's Avatar
Sabreman will become famous soon enough
I am in the same situation as you. I've always had the foot attached. I am ordering a new main within the next few weeks and narrowing my choice to manufacturers and cut (cross-cut vs. North Radian or Quantum Fusion). But one choice is clear. I will definitely go with loose footed. To put it in perspective, the vast majority of jibs are loose footed. The reason why we still use a boom is because it is impractical to sheet a main without it.
Pros:
1. Better sail shape control because there is no foot
2. No flattening reef needed
3. Easier construction because a shelf does not have to be made & slides do not have to be fitted = reduced cost.
4. Easier control because you don't have to fight sail slugs on the boom
5. Easier furling and reefing because the foot is free.
Cons:
1. A tendency for foot flutter. Corrected with a foot line.
Sabre 38 "Victoria"
Old 02-02-2011
DrB DrB is offline
DrB is on a distinguished road
What he says
Pros:
Cons:
Loose foot it.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
Old 02-02-2011
paulk's Avatar
paulk is on a distinguished road
We've gone with a loose foot for the last two mains, though originally we did have a boltroped foot that was attached to the boom. The pros mentioned above are all true. We've had no trouble with "foot flutter".
Old 02-02-2011
jackdale's Avatar
jackdale will become famous soon enough
There have been a few discussions prior.
http://www.sailnet.com/forums/seaman...hats-best.html
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 02-02-2011
jaschrumpf's Avatar
1975 Newport 28
jaschrumpf is on a distinguished road
What does a loose foot main sail look like on the boom? Does the boom even come into play any more?
Every boat I've ever been on has had the bolt rope in it; I'm envisioning the old-style wooden ships setup where the sail is attached to rings that slide along the boom. Does anyone have a good photo showing the differences?
S/V Free Spirit
Monrovia, MD
Old 02-02-2011
Liquorice's Avatar
Liquorice is on a distinguished road
I've got a C&C 26.
Originally the boat had a bolt rope on the foot.
I bought a new set of sails 3 seasons ago with a loose footed main.
I much prefer the loose foot.
- seems to set better.
- easier to see the results when trimming, or maybe it's psychological.
- I don't get any foot flutter!
The foot shelf is supposed to help prevent boundary layer crossover under the boom, thus improving lift, but the increase in effectiveness of the new sails, makes this loss (if there truly is one at 6 knots) unnoticeable!
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Old 02-02-2011
Liquorice's Avatar
Jaschrumpf,
The foot has one large (long) slug at the clew.
(Some racers replace this with a webbing loop velcroed in place)
sam :-)
Old 02-02-2011
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Here's what it looks like:
The boom provides both an attachment for the mainsheet and a means to flatten the sail (by pulling on the outhaul) and/or the vang.
A loose-footed sail usually droops below the boom (like this one does) to provide better air-flow across the lower part of the sail... but it doesn't have to:
Note: The boat the pic is taken from in the top pic has a slug to hold the clew on - the one in the bottom pic uses a webbing strap. The blue line is the reefing line.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Outhaul for Loose Foot Main Quickstep192 General Discussion (sailing related) 21 06-06-2011 12:07 PM
Loose Foot vs. Attached—What's Best? Dan Dickison Seamanship Articles 12 05-18-2011 12:33 PM
Foot of main when reefed? jaschrumpf Learning to Sail 12 09-10-2010 12:39 PM
Sloop rigged with loose-footed main (no boom)? toastchee General Discussion (sailing related) 13 03-09-2010 07:38 PM
Boom Bags and Loose Footed Main tdw Gear & Maintenance 5 03-10-2009 09:20 PM
