Old 02-03-2011
hans737 is on a distinguished road
Engine instrument installation
Wondering if anyone has any insight into installing engine gauges on my Yanmar on a Hunter 380. I want to keep the idiot lights and warning horn intact as a secondary so will need find a way to attach another sending unit for the water temp indicator and oil pressure. Was thinking of teeing into the water lines that run to the hot water heater from the engine for the water temp sender but not sure what would work best for adding the oil pressure sender. I've heard of installing a tee in the current oil pressure attachment hole then somehow putting both sending units (one for the light/horn and one to the gauge) into the tee. Anyone have any luck trying this. I'm getting tired of motoring around waiting to find out I've overheated after the engine dies...
Old 02-03-2011
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
I agree that it is far better to have gauges than idiot lights. A tee fitting to connect the Oil pressure sender, next to the Oil pressure switch would be fine - if you can fit it. If not, you can run a high pressure hose to where your current Oil pressure switch is, and tee a sender and the switch at some more convenient location.
However, I recommend being more careful with the water temperature sender. A tee fitting will not allow the sender to be in the actual flow of water, and may trap air. In either case you will get a lower reading than you should.
I carefully drilled and tapped a hole into my thermostat housing next to where the temperature switch is, to accept a water temperature sender for my gauge panel.
Old 02-03-2011
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
You can change the oil pressure sending unit to a dual station unit and you should have a couple locations ( that are factory plugged ) to add additional temp sender
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 02-04-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Been thinking of doing that also as I don't like the idea of just the water temp idiot light. I'm fine without the oil pressure gauge. Remember the sensors need to be grounded, so cutting the water hose and putting in a tee won't work unless you use a bronze tee and ground it to the engine.
Old 02-04-2011
remetau's Avatar
remetau is on a distinguished road
I switched to Murphy gauges. They have an output for an alarm built into the gauge.
Don & Diana
sv Re Metau an HC33t
Old 02-04-2011
galynd is on a distinguished road
remetau,
do you know model # of water temp and oil gauge? does it come with the alarm or did you connect to existing alarm?
thx
Old 02-04-2011
remetau's Avatar
Murphy EGS guages
Temp: EGS21T-250-12
Pres: EGS21P-100-12
I used my existing Yanmar buzzer and idiot light for the alarm.
Don & Diana
Old 02-04-2011
Thanks remetau.
Whole new instrument/nav self installation? JPGaillard Electronics 5 06-26-2009 09:52 AM
Engine Installation; advice required! RichP Gear & Maintenance 18 10-18-2008 11:05 PM
pur watermaker installation/engine intake rrgane Gear & Maintenance 6 05-06-2008 10:11 AM
engine facing aft with saildrive installation levenezia Gear & Maintenance 3 01-16-2005 10:35 AM
New Engine Installation cgates General Discussion (sailing related) 8 09-18-2003 11:06 AM
