Questions about Ecowind Four Blade Max-Prop - Page 5 - SailNet Community
post #41 of 42 Old 02-23-2011 Thread Starter
Well I managed to get over to PYI's booth at the Miami Boat Show on Monday and lo and behold they had an actual Eco Wind prop on display. Just from looking at it, it is solidly built. The "spring" is interesting it's (be forewarned, this is a non-engineer's description) a spring material ring with slits cut in it. RPM's, water pressure, torque apparently compress the ring which in turn changes the pitch. I too am befuddled by the physical process, which was why I started this tread in the first place to see if anyone had any on hand experience. So far the answer to that (at least on Sail Net) is no. The PYI rep told me that 3 dozen of these props had been sold so far. He also told me that the 1.5 inch shaft version is in testing right now with plans for it to be available for sail starting in June. The price for the 1.5 by the way will be closer to $7,200 not the $5,600 for the smaller shaft.
I also got to look at the VariProfile 4 blade prop, which was a sweet little package, but doesn't portend to really increase efficiency or power motoring forward, which was what I was looking for primarily.
So now I am totally confused and have decided to leave the fixed three on for the time being.
GypsyPaula is offline
post #42 of 42 Old 02-24-2011
Brezzin's Avatar
Wow- 7200.00 for a the 1 1/2 shaft. That's difficult nut to swallow. With a standard Max-Prop for half of that. I really have to ask myself now if the greater speed at lower RPM (a claim yet to be verified) is worth the that kind of money to me.
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Brezzin is offline
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 07:52 AM
3 blade prop maybetuezday General Discussion (sailing related) 19 11-28-2010 11:50 AM
2 Blade vs 3 Blade prop PBzeer Gear & Maintenance 23 01-02-2007 09:43 PM
Three Blade Prop KenD Gear & Maintenance 4 10-21-2003 06:39 PM
three blade prop KenD General Discussion (sailing related) 8 06-18-2002 02:23 PM
