02-06-2011
I don't discuss my member
Originally Posted by chrisncate
You are technically correct, however for the typical everyday sailor who does not have access to dive equipment, nor the skills to do this job underwater, it's a job typically done in a haul out scenario.
But you already know this I suspect, correct?
The typical everyday sailor who does not have access to dive equipment, nor the skills to do this job underwater would normally hire a professional to do a job like this, just as he would hire a mechanic to work on his engine or a rigger to replace his rig. It is cheaper, faster and more convenient to have a skilled, knowlegeble diver do it while the boat is in the water than to haul the friggin' thing for what is essentially a pretty easy job that can be done in an hour or two.
FYI to all- there is almost no prop work that cannot be performed while the boat is in the water and that goes for fixed, feathering or folding props.
"Clean bottoms are FastBottoms"
