Wanted: Striped Bass Poachers in the Chesapeake - Page 3 - SailNet Community
post #21 of 86 Old 02-09-2011
Doesn't sail enough
zedboy's Avatar
Originally Posted by travlineasy View Post
[...] and a host of other species, both pelagic and anadromous. [...]
(reaching for dictionary)
Gary, you are a bona fide Maryland state treasure.
zedboy is offline
post #22 of 86 Old 02-09-2011
Kiltmadoc's Avatar
Achh, who wants to eat striped bass anyway? They are full of poison:
Wild striped bass - Seafood Selector - Environmental Defense Fund
Kiltmadoc is offline
post #23 of 86 Old 02-09-2011
Looking at those charts I shouldn't be alive.
lapworth is offline
post #24 of 86 Old 02-09-2011
Chastened
Ajax_MD's Avatar
You just have a tough constitution.
1981 Tartan 33 #168
Ajax_MD is offline
post #25 of 86 Old 02-09-2011
travlin-easy's Avatar
Cool
The Maryland Department of Environment continually updates it's fish consumption health advisory charts, the last one being in 2007. Much of this seems to be politically driven, the agency claiming at one time that commercially caught fish were perfectly safe to eat, while those caught by hook and line were not. WHAT? This, of course, was sheer lunacy, and I suspect the statement was made to the press in a futile attempt to protect, and possibly bolster, Maryland's failing seafood industry.
If you carefully examine the charts, most species have been contaminated with either PCBs or mercury, both of which are lethal. And, from my experience working in the medical field for nearly 15 years, there is no safe level of PCB or mercury. Even in tiny amounts, spaced over a wide time frame, both are toxic to every form of life. And, from what I've read, mercury is a cumulative toxin that the body cannot rid itself of. It is so toxic that when a school nurse accidentally breaks a thermometer the school is usually shut down until a hazmat team comes and clears any remnants of mercury from the area. Now, that may be a bit of overkill on the part of the school system, but what idiot at the Maryland Department of Environment, Health Department, FDA, etc... decided that we can safely consume mercury and PCBs embedded in our food supplies?
If you want seafood, go for the farm raised variety--it's much fresher, and much safer to consume. Here are a few guidelines for selecting seafood that I wrote about several years ago that may be helpful:
1. Use the "sniff test." Smell the fish, crab meat, etc... If it smells fishy, it has spoiled, or in the process of spoiling. And, there's a good chance it's loaded with bacteria.
2. Firmness. If the product, particularly fish fillets, are firm, this is a good indication it is relatively fresh. The term "relatively" essentially means it was caught with two days, properly iced down or flash frozen, and shipped iced or frozen to the retailer within a day of reaching the wholesaler.
3. Local (home grown) does not translate to fresh. The sniff test will prevail here.
4. Toxins. Oily species of fish tend to contain the most toxins. Bluefish, tuna, king mackerel (kingfish), billfish, weakfish, etc... are on the list of those containing the highest levels of mercury. Striped bass, flounder, black sea bass, shark, spiny dogfish, perch and most freshwater species usually contain less mercury and PCBs, but they still have relatively high levels in the fatty tissue just beneath the skin, and the dark tissue along the lateral lines. Blue crab contains high levels of toxins in the hepata-pancreas (mustard).
5. Remove the skin and rinse thoroughly. With many species, particularly those that are somewhat oily, removing the skin and thoroughly rinsing the fillets in cold, fresh, running water will decrease the amount of toxins by a significant degree. You CANNOT get rid of ALL the mercury and PSBs because some of it is embedded in the meat itself, but removing as much as possible will help to some degree.
6. Preparation. All forms of seafood should be thoroughly cooked. Granted, there are Sushi Bars and Raw Bars that serve raw seafood, claiming "No one ever got sick eating at my restaurant." Yeah, right--I still believe in the tooth fairy, too! Consuming raw seafood is foolish, especially in this day and age when the water quality where that animal was caught is considered highly toxic or bacteria laden. This includes all of Chesapeake Bay and it's tributaries, and for the most part, every major body of water in the U.S., Europe, South America, and Asia.
7. Farm raised is safer. Most aquaculture operations must meet rigorous health standards and are inspected regularly. This is true of both finfish and shellfish. In many instances, the water flowing in raceways is filtered to minimize contamination of the product. Shellfish, such as oysters and clams are usually raised on floating platforms so they are not subjected to the toxins found in the body of water's bottom sediment. When harvested, the process is very quick, efficient and in most instances the product is cleaned, washed thoroughly and flash frozen. With the exception of shrimp, shellfish, are usually iced down and shipped live. Farm raised shrimp, also called zebra and banded shrimp, are harvested, beheaded, cleaned, washed and flash frozen, then usually shipped the same day. It's rare that farm-raised shrimp fail the sniff test.
8. Eat small portions. The days of consuming huge quantities of seafood are over.
Eat Mo Chicken!
Gary
travlin-easy is offline
post #26 of 86 Old 02-09-2011
Chastened
Ajax_MD's Avatar
Farm raised fish aren't the be-all, end-all though. These fish are jammed into close proximity to each other for extended times. Think of it as a dirty city. They get sea lice (yes, there is such a thing). They also transmit the sea lice to wild fish that pass near the fish farm containment net.
1981 Tartan 33 #168
Ajax_MD is offline
post #27 of 86 Old 02-09-2011 Thread Starter
T37Chef's Avatar
not to go to far off topic...but here is a link to the Monterey Bay Aquarium's Seafood Watch Program, you can print off a pocket card to keep on you by region/state Download a Regional Seafood Watch Card | Monterey Bay Aquarium
Shawn
T37Chef is offline
post #28 of 86 Old 02-09-2011 Thread Starter
T37Chef's Avatar
Eat Mo Chicken!
Gary
Then the chicken farms will pollute the bay even more
Shawn
T37Chef is offline
post #29 of 86 Old 02-09-2011
kd3pc's Avatar
just proves the age old adage of don't crap where you eat or drink...
what do you expect when for 40+ years WE dump 7 states worth of manure, pollution, chemicals and sewage in to the Bay.
CBF brokers away a solution with those know it alls at the EPA, and we still have no solution...just a lot more chatter and even more platitudes...
I will likely not live long enough for the Bay to be cleaned up, let alone management of it's resources to be made on a common sense basis.
kd3pc is offline
post #30 of 86 Old 02-09-2011
Pearson 303
SVCarolena's Avatar
"Farm raised is safer. Most aquaculture operations must meet rigorous health standards and are inspected regularly."
Just one word of warning on this statement - when buying farm raised, pay careful attention to where the seafood is raised. I started paying closer attention at the grocery a couple years ago, and was amazed at the amount of seafood that comes out of Asia and, in particular, China. I'm fine with farm raised from the US/Canada (and am sure these foods do meet "rigorous health standards" and inspections), but there is no way I'm buying farm raised from overseas. We all know that track record when it comes to food safety. And, as an added benefit, we can keep our dollars closer to home, but that is for another thread.
SVCarolena is offline
Crew wanted for FL. to Chesapeake Bay TomCat27 Crew Wanted/Available 14 04-14-2010 03:37 PM
Upper Chesapeake Bay daysailor crew wanted redcobra Crew Wanted/Available 9 08-26-2009 11:14 PM
CREW WANTED-Penobscot Bay (Maine) to the Chesapeake Westsail32 Crew Wanted/Available 3 07-30-2007 03:28 PM
2 crew wanted for late June Chesapeake cruise peter.maroney Crew Wanted/Available 0 05-31-2006 02:20 AM
Crew wanted, Portsmouth NH to Chesapeake ewilliams Crew Wanted/Available 1 08-27-2005 12:43 PM
