First, shortening scope is the WRONG THING TO DO. It makes it far more likely that you'll pull the anchor out.
Second, adding a second anchor to the stern means that if the wind shifts significantly,
it will be blowing against the PROFILE of the boat, and very likely will RIP BOTH ANCHORS FREE. From a post by Rich_H on jacklines, the reasoning for this is:
For you with math ability ... when you apply load perpendicularly to a 'taut' line, the reaction load in the terminal ends is the perpendicularly applied load divided by the sine of the deflection angle. Dividing by small deflection angles (taught line) result in forces approaching 'infinity'; the more slack the 'line' the larger the deflection angle (dividing by larger sin value); hence, lesser reaction loads in the 'terminals'.
How big is this boat? 3/8" line is worthless as an anchor line for anything larger than a daysailer IMHO. It would help if you said what kind of boat he has as well as what kind of anchors he is using.
BTW, if the boat is bigger than a daysailer, it is likely that you're straining the anchor line past what is safe to do so. Also, the best anchor lines are NYLON, as that has much better characteristics for an anchor line than does polyester or polypropylene lines.
Without knowing more specifics, it is hard to give you decent advice. Generally, the more relevant and specific information you give related to a problem, the better the quality of the answers you'll get.
As for using a second anchor off the bow, I generally don't recommend this, unless you know what you're doing. The two rodes can chafe against each other and cause you to lose both anchors.
A better idea might be to use a bridle to help keep the boat from hunting side-to-side. A riding sail, which is what Ardoin describes, might also help.
Originally Posted by millyman01
my boyfriend is in the FL Keys and sustained 20 mph winds @ his anchorage his boat keeps whiplashing. At the end of each yank it is pulling hard on the anchor and he is worried about anchor drag! He shortend up his scope and put the smaller anchor at the rear but the wind is still pushing the boat sideways straining both anchors. He is wondering if his 3/8 ths polly rope is too springy which is causing this, also boater supplies in key west are out of business other than sears or home depot not sure where to buy better rope?
