02-12-2011
Well, how much moisture migrates out depends on a lot of factors, like the temperature, the ambient humidity, whether the gelcoat has been peeled or not, etc...
Originally Posted by sailordave
Reading REDHAIREDGAL's thread about their Contest 34 and hearing other folks tales of woe regarding blisters and water absorption.... and knowing you don't want water to sit in the bilges... set me to thinking. (always dangerous  )
Has anyone every calculated how much water gets aborbed in a hull made of the various resins and how fast it is absorbed?
If you haul out a fiberglass boat and let it sit for X amount of time has anyone every quantified how much moisture would migrate OUT of the hull and compared that w/ how much was in the hull to start? I would suspect it would be a very slow process otherwise we'd all have soggy, watersoaked hulls in short order.
Just the morning mind worm...
