Just bought a 1979 Islander Bahama 30 today - Page 2 - SailNet Community
post #11 of 47 Old 02-15-2011
You should be arrested for grand theft
omaho5 is offline
post #12 of 47 Old 02-15-2011 Thread Starter
haha.
SpcAlan1 is offline
post #13 of 47 Old 02-18-2011 Thread Starter
Hey guys.
I 'tried' to raise the main sail yesterday - very, very tight halyard.
New sail, new 'slugs', and new halyard makes for a tough pull ( even with winch ). After breakng it in, it got better, but never really got it 100% up. I may have to oil the pulleys on top of mast - yay me.
This boat has so many pulleys ( a lot more than my Catalina 25 had ). I wonder if I have it setup correctly.
There are 2 sets of 3 'roller pulleys' on each side of the mast that I can use to route the main halyard to the cockpit, not sure which to use, which may be causing the stiffness in raising the main.
I may have someone more experienced take a look at it.
SpcAlan1 is offline
post #14 of 47 Old 02-18-2011
Did you clean the mainsail track and lube it with SailKote? Also, one issue that can cause a problem is if the main halyard is spliced, since the splice may be too thick for the sheave and cause the halyard to bind up before you get to full hoist.
Photos will help.
BTW, the main halyard, usually on the starboard side of the mast, will generally come back to the cockpit on a set of deck organizers to starboard.
sailingdog is offline
post #15 of 47 Old 02-18-2011 Thread Starter
it was tough with no sail on the halyard, and almost impossible with the sail on. i will use the sailkote, but this is something different causing the problem.
SpcAlan1 is offline
post #16 of 47 Old 02-18-2011
Send a message via AIM to HPLou
Congratulations on your new boat, she is a beauty. As for the the halyard, it may have jumped the sheave. Good luck with her.
HPLou is offline
post #17 of 47 Old 02-18-2011
Did you run the halyards yourself? If so, it sounds like they're not running fair or free.
post #18 of 47 Old 02-18-2011 Thread Starter
No, the halyard was already up.
So this can be a 'stuck' pulley at the top, maybe needs oiled?
Could be the halyard 'off-track' from the pulley?
SpcAlan1 is offline
post #19 of 47 Old 02-18-2011
Unless the sheave is damaged or the slot was way oversized for the line and sheave, this is pretty unlikely.
Did you run the rigging or was it already run? If you ran it, you might have accidentally tangled or twisted two of the lines around each other, which would lead to a lot of friction for no visible reason.
post #20 of 47 Old 02-18-2011
The Elephant
smackdaddy's Avatar
I had the same thing happen on our boat when I went up the stick to change the anchor light bulb. The sheaves were old and the one I was on essentially disintegrated with the weight (it was plastic). Lesson learned.
I replace both sheaves and everything was a lot easier to haul.
smackdaddy is online now
new islander 30 bahama in seattle merlinislander Islander 4 11-05-2012 04:57 PM
Islander Bahama 24' as first boat? micetic Boat Review and Purchase Forum 13 06-08-2012 02:36 PM
Islander Bahama 30 Manual OopsIslander Islander 12 03-10-2012 01:38 AM
Islander Bahama 30 rlange Islander 16 05-14-2011 11:12 PM
80 Islander Bahama 30 NCountry Islander 1 03-29-2009 11:16 AM
