Old 02-14-2011
Ranthra is on a distinguished road
Composting heads - remove thru-hulls?
First, thanks for all the comments in other threads about composting heads. We've decided to go with a Nature's Head. The old head and hoses have been removed already.
For those who've gone this route, did you remove the thru-hulls or just leave them? Our valves are currently closed ( obviously ) and plugged, but I'm thinking of having them glassed over. Any suggestions ?
Old 02-14-2011
If you're sure you're not going to need them, I would definitely glass them over.
Old 02-14-2011
LauderBoy is on a distinguished road
Just put my Nature's Head in last weekend which freed up 1 through hull. I might use it for an internal AC/heater. But however much my carryon AC annoys me, I've heard internal AC's can be a PITA, so I may just nix that idea and glass it up.
Old 02-14-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
I would wait a year. Friends of mine just took their composting head back out after about 6 months. Then do what you like.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 02-14-2011
DulceSuerna's Avatar
DulceSuerna is on a distinguished road
Any idea why they took it out or what they didnt like about it?
Old 02-14-2011
pdqaltair's Avatar
Their reasons are posted on their blog, here:
More pottie talk | Zero to Cruising!
I was not trying to say whether this was right or wrong, only that it might be reasonable to leave the holes intact until the next haul-out.
Old 02-14-2011
chrisncate's Avatar
Mango intolerant
chrisncate is on a distinguished road
Just read the write up, never considered insects as a problem..
We almost pulled the trigger on one, we decided to stick with out normal head though. Good blog post that is worth the read either way.
Old 02-15-2011
Yeah. That's not the first post I've read about insect problems either. I think it's something you need to take in account with a composting toilet install and maintenance.
I think with any system you're trading one set of problems for another set of problems. It's mostly a matter of what problems you prefer to deal with.
Old 02-15-2011
Be aware that in some areas, you may run into legal issues with a composting head. The way some of the laws are written, the composting heads can fall into strange grey areas.
Old 02-15-2011
travlineasy's Avatar
Morgan 33 O.I. Perryville
travlineasy is on a distinguished road
Sounds like a disaster. And, from the writeups, the operation of the device sounds similar to an ordinary septic system, which is slow even when enzymes are added regularly. Guess I'll stick with the holding tank and pump-outs.
Gary
Composting Head? saltyoldman General Discussion (sailing related) 1 05-24-2009 01:09 AM
Composting Marine Heads CaptainForce Gear & Maintenance 25 05-05-2009 10:13 AM
do i need to remove rudder to remove shaft 37cc jumpnkd Irwin 4 04-13-2008 10:48 AM
Composting Toilets tumblebug General Discussion (sailing related) 1 02-10-2008 02:39 PM
Composting Toilets tjvanginkel Gear & Maintenance 23 09-23-2007 11:43 AM
