I just don't get it. Winter Storage - Page 4 - SailNet Community
post #31 of 32 Old 02-16-2011
I made a similiar frame from pvc years ago and its still going strong. If it will help, several points that have worked well on my frame...I drilled 2 holes in pvc center ridge about every three feet
for 3/4" ribs which pass though center ridge and connected 2 pieces of the 3/4"
rib material as needed then cut to desired size , they fit into holes in pvc that run along
(inside) port and starboard toe rails.(ribs and all numbered) This creates tension that works well and can be carried all the way back to the stern. Another big help is using plastic ties to hold things in place when setting up and from wind, come spring they cut off real easy.
Pretty strong, stands up to wind and snow.
Hope this helps.... Hugo
Thumbnails
HUGOSALT is offline
post #32 of 32 Old 02-16-2011
Chastened
Ajax_MD's Avatar
Originally Posted by treilley View Post
Check out Dr. Shrink. They carry everything you need and cater to DIYers.
That is too cool, thanks! I believe that I'll try this next winter.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
Winter Storage jbondy Gear & Maintenance 1 09-12-2008 10:25 AM
Winter Storage!?! eherlihy Boat Review and Purchase Forum 9 08-28-2008 03:58 PM
water storage vs. land storage during winter apkaplan General Discussion (sailing related) 1 10-24-2007 04:50 PM
Winter storage? jpeac2 General Discussion (sailing related) 14 03-25-2006 08:35 PM
Winter Storage RPerreca General Discussion (sailing related) 7 06-15-2001 05:34 AM
