A Nice Little Conundrum - Page 2 - SailNet Community
post #11 of 67 Old 02-16-2011
RichH's Avatar
More info neded. Is this a to windward or to leeward finish?
RichH is offline
post #12 of 67 Old 02-16-2011
Learning the HARD way...
eherlihy's Avatar
Assuming that both boats are heading in the same general direction toward the same finish line, and that the statement "Boat B has no wind" does not mean apparent; Boat B would have 10 Knots apparent ON THE NOSE. This will slow boat B..
Boat A would have 0 Knots apparent.
Boat A wins
eherlihy is offline
post #13 of 67 Old 02-16-2011 Thread Starter
tdw
Super Fuzzy Moderator
tdw's Avatar
See OP....10 knots from astern but to be completely clear both boats are directly downwind from the finishing line. Current is also running in same direction as wind.
I'll post answer later in the day. It is as much the why as the winner.
I had a lot of fun with this. Hell, me and the Wombet nearly came to blows .
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #14 of 67 Old 02-16-2011
RichH's Avatar
Both are in a ten knot current flowing in the same direction as the boats.
Boat A has ten knot true wind from astern, Boat B no wind.
What will be the result ? A wins
Why ? because A is drifting toward the line at ~10kts but has 0 kts *apparent* across the sails and total forward speed to the mark is 10kts.;
B is drifting at 10 knots but with -10 knots (current v 'minus' TRUE wind ( approx. NEGATIVE 10 apparent ) across the sails ...
Rx: Both in same v of current; A has 0kts apparent; but B has NEGATIVE approx. 10kts. 'apparent' wind
RichH is offline
post #15 of 67 Old 02-16-2011
Aren't the boats upwind from the finish line if the wind is astern?
1979 Gulfstar 37 Laissez Faire
rmeador is offline
post #16 of 67 Old 02-16-2011 Thread Starter
tdw
tdw's Avatar
The finishing line is downwind from the boat with the following true wind. The second boat has no true wind so the point is moot.
― Terry Pratchett.
tdw is offline
post #17 of 67 Old 02-16-2011
Boat A has 0 apparent wind because he is moving at 10kts with the current and the wind is also 10kts in the same direction. Boat B has 10kts apparent wind on the nose, so if they are allowed to change course (i.e. tack), boat B can sail upwind and get there first.
rmeador is offline
post #18 of 67 Old 02-16-2011
Yes. One assumes neither is motoring, and both theoreticaly can sail, but only one has relative wind. To say that B will be slower because the wind will push it backwards either assumes it can't sail or that no yacht can sail in 10 knots to windward.
Of course in the real world of sailing A would lose the wind and B would gain it so the positions would be reversed.
chris_gee is offline
post #19 of 67 Old 02-16-2011
ne57301's Avatar
"See OP....10 knots from astern but to be completely clear both boats are directly downwind from the finishing line. Current is also running in same direction as wind."
If you have 10 knots coming over your stern and the current is flowing in the same direction, and the finish line is directly upwind, you are going straight away from the line in a big hurry. Neither boat will ever finish.
1984 Pearson 34 hull #67
1978 Pearson 30 hull #1049
Freeport, ME
ne57301 is offline
post #20 of 67 Old 02-16-2011
"Boat A has ten knot true wind from astern, ...
...both boats are directly downwind from the finishing line."
Sorry, fuzzy, but if that's all true BoatA must be sailing backwards, right?
Which is of course possible and legal within the rules. Probably means BoatB is going to win since BoatA is being blown away from the line and BoatB isn't.
hellosailor is offline
A Conundrum, without an Answer Jasper Windvane General Discussion (sailing related) 50 11-17-2009 10:15 PM
Flag Etiquette/Registry Conundrum Mimsy Cruising & Liveaboard Forum 32 04-02-2009 03:53 PM
Nice Girls, nice photos PORTUGAL MATCH RACE Giulietta Racing 14 09-02-2007 12:44 AM
