02-16-2011
Usually on a boat with a prop within an aperture the tip clearance to the aperture is 'vitally' important. If you have the extra rpm available (most boats are 'underpropped' anyway which causes the engine to 'lug' - never develops full hp because the prop limits max. rpm at 'full throttle'); then, usually a smaller prop will allow the engine to 'spin' for max. rpm/ max. hp output .... and by opening the tip clearance, you lose the 'heavy helm pressure'.
If you are also getting 'vibrations' as well as or along with the helm pressure - as felt on the steering wheel, then most probably the prop is TOO BIG for your aperture. Either remedy of opening the aperture space or smaller diameter prop. usually mitigates both - the vibration and the heavy helm.
The shape of the prop tip is also important vis a vis 'tip clearances' in an aperture, and thats why I recommended a 'consult' with a knowledgeable 'expert' AT a prop mfgr (application engineering section).
In my experience with a 'throbbing', heavy handed helm, going to a smaller diameter and change of tip profile shape (and also opening the aperture)... changed my boat to a non-vibratory and 'neutral' helm. I now have a 'short-hub' Max-Prop ... and after many pitch change adjustments have settled in with a good match for max. rpm, max HP output, and no heavy / throbbing helm.
I also changed the leading edge shape of the 'opened' aperture (to similar to a NACA '010' shape)... less rudder turbulence, better hydrodynamics and rudder efficiency.
The hogwash about a full keelers barn-door rudder is just simply that - hogwash, as if the boat is properly 'sail shaped for correct balance' the rudder will be no more than a few degrees (2-3°) off of the centerline ... and if thats the case then all the 'neck vein-popping arguments' about barn door rudders 'go out the window'. You're certainly not 'frantically racing around the buoys' in a heavy weight full keeler with a barn door rudder. ;-)
