alternator question - SailNet Community
post #1 of 4 Old 06-11-2003 Thread Starter
alternator question
Hi,
Is it possible to get and alternator and use it with an outboard to charge a battery? Or must I get an engine with this facility the first day? I have a 6hp evenrude and want some setup that will charge a battery for me...
thanks for any suggestions
dave_oc is offline
post #2 of 4 Old 06-11-2003
alternator question
Alternator Kits (add-on) are available from OMC.
GordMay is offline
post #3 of 4 Old 06-11-2003
alternator question
You didn''t mention how much power you might need from your battery. i.e. how many amp hours will you be drawing from the battery that you expect the alternator to re-charge.
Most small outboard alternators are very low output affairs as compared to automobiles or inboard alternators. Before you spend your money, make sure the alternator has enough output to keep your battery charged.
Jim
joub1 is offline
post #4 of 4 Old 06-12-2003 Thread Starter
alternator question
I haven''t work out what I need at all - I''ll use whatever I can get! thanks for the help!
Dave
dave_oc is offline
